Power Steering pump
Old Feb 17, 2003 | 10:39 AM
SkyBlue69's Avatar
SkyBlue69
Question Power Steering pump
My Pump leaks very badly around the threads for the hoses and I have to check and top off the fluid often. Here is my question. 1) Is the pump under pressure if the engine is not running where I can unscrew the lines and 2) can I use Teflon tape to try and tighten down on the threads? I thank you for the help.
Old Feb 17, 2003 | 02:04 PM
mk's Avatar
mk
Power Steering pump
There isn't any pressure when it's not running but you should place some kind of pan under the truck as there will be a fair dribble from the line and pump when disconnected. I would suspect a bad o-ring on the pressure line fitting or a loose clamp on the return line.
mike
