What makes engine fire up quickly?
Old Feb 17, 2003 | 10:13 AM
robjohn's Avatar
robjohn
I have a 82 F100 w/ 302 2bbl carb. I also had a '79 that was extremely similar as far as major components go. The 79 would fire up practically instantly after turning the key while my 82 takes about 2.5 seconds of cranking to fire up. Sometimes I let go and try again for about the same duration before it runs. Why? The 2.5 seconds seems like an eternity. Also, in cold weather, do these trucks always have to die at least once? Both trucks insist on being started twice when its < say 40ish deg F or so.
Old Feb 17, 2003 | 04:06 PM
Franklin2's Avatar
Franklin2
Sounds like your choke adjustment is off. And it's not that easy to get it just right. It takes alot of experimentation with the round black choke housing adjustment.
Pkupman82
Sep 23, 2012 10:16 PM
2hole
Jan 18, 2012 02:23 PM
mtgrzlyman
Jan 7, 2011 04:27 PM
slpin
1978 - 1996 Big Bronco
Sep 29, 2006 10:14 PM
Chugalug
Engine Swaps
May 20, 2004 08:41 AM
