If you upgraded to 3" plenums you will have to come up with a different y-pipe. I have heard that if you can weld aluminum you can take a SD spider and marry it to the OBS turbo connection forn an early '99. Lotta work though!
I have Beans billet aluminum 3" plenums. And I have the 3"y-pipe from Hypermax with the H2e kit I got from Beans.
There are alot of ways to do this upgrade but you must be creative as there is no "bolt on" way to do it with the stock turbo that I know of.
Another option to consider is the Banks spider, you need two parts, the Twin-Ram and the compressor outlet. The parts are available from Banks individually, you don't have to buy their entire IC kit, or start looking for used parts. When I did my IC install the early 99 spiders were hard to get and expensive on ebay. Banks is very spendy as well, but it's easy bolt on and uses the stock boots and clamps at the plenums and the compressor. They fit well and don't block the oil fill, dipstick, or fuel filter access.
