Sponsored by: Real Truck
Floaty steering
Old Aug 26, 2010 | 11:04 AM
jc8825's Avatar
jc8825
Floaty steering
When driving off road or even over uneven paved roads, such as near a construction site where the road way is different heights, the truck really wants to pull every which direction over these spots. I have to fight it. Is this a worn steering damper/stabilizer? The truck has 203K, so it would be about time...
Old Aug 26, 2010 | 12:17 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If it just pulls in whatever direction the road leans, or pulls back and forth over uneven road, that's not a stabilizer.
Sounds like something's loose or your alignment is off.
Old Aug 26, 2010 | 01:42 PM
jc8825's Avatar
jc8825
What could be loose?
Old Aug 26, 2010 | 02:07 PM
krewat's Avatar
krewat
Ball joints, tie-rod ends, pitman arm, wheel bearings, spring bushings, whatever
Old Aug 26, 2010 | 02:26 PM
rickf92592's Avatar
rickf92592
Could be not enough caster.
Has it been lifted?
Old Aug 26, 2010 | 04:19 PM
jc8825's Avatar
jc8825
It's not lifted, it is all stock. It just likes to go where the roads tells it to, not necessarily where I want it to.
Old Aug 26, 2010 | 05:10 PM
Monster-4's Avatar
Monster-4
Do the following first.
1.) Tighten the gearbox 1/4 turn or so. Take it for test drive and try another 1/4 turn adjustment. Rinse and repeat. If you feel high resistance while tightening the the adjustment bolt in the steering box you went too far and need to back off. If you over tighten the box you'll destroy it.
2.) Replace power steering fluid.
If you still are having issues.
1.) Check ball joints.
2.) Check drag link and tie rods.
3.) Check front bushings and the springs themselves.
4.) Check track bar bushings.
5.) Check wheel hub.
6.) Replace anything that looks worn out.
7.) Have an alignment done.
And finally
1.) Look at replacing the steering box.
Old Aug 26, 2010 | 05:14 PM
jc8825's Avatar
jc8825
What is the procedure to drain the power steering fluid out?
Old Aug 26, 2010 | 05:20 PM
Monster-4's Avatar
Monster-4
Below is a link for the PSD since it's different then the gas engines. The PSD has the HydroBoost which the gas engines don't need.
Ford Super Duty Power Steering Flush | Superdutypsd.com
Old Aug 26, 2010 | 09:46 PM
Pinky Demon's Avatar
Pinky Demon
Check all your suspension parts first with the wiggle test. I also would recommend a dual steering stabilizer kit.
Old Aug 27, 2010 | 12:02 AM
rickf92592's Avatar
rickf92592
I'm sure you meant to say to check for binding at full-lock both directions because that's where it will bind first and the damage will occur.
There needs to be some slack when the steering is centered because that is where the steering gears are most worn and removing all of that slack will bind the gears when turning.
halfbolt
6.7L Power Stroke Diesel
May 3, 2014 07:39 PM
Heavy One Fifty
Aug 2, 2010 04:40 PM
cterrysgd
Oct 5, 2005 01:01 PM
crazed87bronco
1978 - 1996 Big Bronco
13
Jan 19, 2004 08:13 PM
Red Raider 4x4
Feb 2, 2003 09:13 AM
