vacuum question
Old Aug 25, 2010 | 08:13 PM
limptera13's Avatar
limptera13
Exclamation vacuum question
almost done puttin my c6 in replacing my the manual that was in there . my question is on the back of the trans where does the vacume line run up into the engine? there is a lil 3 outlet vacuum T piece on the firewall, and one of them is capped off/? can i go here or do i go somewhere else?
Old Aug 25, 2010 | 09:11 PM
Franklin2's Avatar
Franklin2
You can go anywhere there is manifold vacuum. That tee you described on the firewall will work. If you have a tree behind the carb going into the manifold, that will work also.
Old Aug 25, 2010 | 10:25 PM
FordNFishinLover's Avatar
FordNFishinLover
All the vaccum should be pretty much linked together. Id say just remove that cap from the tee on the firewall and use it. But if your wanting it alittle more hidden id just stick it on the tree behind carb.
Old Aug 26, 2010 | 03:18 AM
limptera13's Avatar
limptera13
i figured thatd work. i kist figured it wouldnt hurt to ask
