Sponsored by: Real Truck
mpg
Old Aug 25, 2010 | 04:45 PM
dmen's Avatar
dmen
mpg
I recently switched tires from the contitracs to bf goodrich at ko. Both tires were 275/70/18. My mpg is going down hill quickly. I don't expect great mileage from the truck, but it is getting ridiculous. Is thier anything I can do to improve a little. I at least would like to get back to 12 mpg.my truck is 06 f250 with the 5.4 cc sb 4x4.
Old Aug 25, 2010 | 04:53 PM
donovan's Avatar
donovan
Tires
The BFG take gas. Did you get a wider tire?
Donovan
Old Aug 25, 2010 | 05:19 PM
dmen's Avatar
dmen
thetires are the same size. i expected a little difference due to the aggressive tread on the bfg, but not as bad as it is.
Old Aug 25, 2010 | 05:24 PM
Kajtek1's Avatar
Kajtek1
Don't think tire thread can cost big difference in mpg.
What I would suspect that even with the same nominal size, the new tires have bigger rolling diameter.
Compare rpm of old brand with the new one, or test you speed with GPS.
Quite possible you are making much longer distance than your odometer is recording.
Old Aug 25, 2010 | 05:34 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
X2 on the outter diameter being off. You have to actually measure the tire to be sure.
How many miles on the truck? If you're getting into the 60/80 range, there might be some engine stuff going on that just coincided with the new tires.
Old Aug 25, 2010 | 06:59 PM
dmen's Avatar
dmen
the truck only has 35k miles.
Old Aug 25, 2010 | 07:05 PM
QwkTrip's Avatar
QwkTrip
How much did the mileage drop?
Worn tires get the best mileage you will ever see. As soon as you replace tires the mileage will go down some. The AT KO isn't very aggressive tread but it won't be as good as a highway tread. A full 1 mpg difference is within reason given the change you made.
Old Aug 25, 2010 | 08:16 PM
Fordfanatic4life's Avatar
Fordfanatic4life
you sure ur truck just doesnt need a tuneup or something ???
perhaps teh timing of teh new tires is just coincidence..
Old Aug 25, 2010 | 08:43 PM
redford's Avatar
redford
FTE Leadership Emeritus
What is your tire pressure?
Old Aug 25, 2010 | 09:19 PM
V8stockcar's Avatar
V8stockcar
Would a taller tire help the mpg's? I have 245 75 17 and looking at
365 70 17 about 1" taller.
03 f350 6.0 got 10 mpg pulling same car trailer.
Truck:
08 F350 Dually
430 gear
v10 6.8
MPG's
9.2 to 9.5 in town
5.5 towing boat 30 ft with T-top
6.5 to 7 Race car trailer 40' GN
Old Aug 25, 2010 | 10:12 PM
Fordfanatic4life
no, taller tires HURT your MPG's...
Old Aug 25, 2010 | 10:34 PM
Thunderduckie's Avatar
Thunderduckie
You're getting 12 MPG?? I envy you. I have owned my '03, 5.4 since new. I have never seen better than 8 city and 10 highway. I did upgrade the tires to 285/95/R16's but didn't notice a drop.
Old Aug 26, 2010 | 02:04 AM
Nathan6.8's Avatar
Nathan6.8
I lost about 1.5 mpg putting the 35x13.50 on mine
Old Aug 26, 2010 | 04:09 PM
bigblue61's Avatar
bigblue61
i lost about .5 with my 5.4 going from 235/85/16 to 265/75/16 duratracs but im still seeing 12 in town and about 14 on the highway sc lb 4x4
Old Aug 26, 2010 | 06:17 PM
texastech_diesel
Token Redneck
Originally Posted by V8stockcar
I have 245 75 17 and looking at 365 70 17 about 1" taller.
Um hate to break it to you, but a 365/70R17 would be 37 inches tall, no where NEAR the 31.5 inches tall you currently have. This has to be a typo, I couldn't even find a tire in this size. You mean 265 right?
