Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Interior walls in workshop?
Old Sep 1, 2010 | 02:01 PM
grandads76's Avatar
grandads76
So, I guess I'm going with OSB. Is the the quarter inch too thin or should I stick with half inch? Also, any suggestions on economical insulation? Here is a pic of the shed now, so you can see what I'm working with. I am waiting on the metal shop to finish with my roll up door, then I'll start with the walls.
Old Sep 1, 2010 | 03:19 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't know about humidity where you are but with a metal shell I would consider rigid foam insulation.
It won't absorb water and become soggy inside the walls and against the steel.
Just my 2c...
Old Sep 1, 2010 | 03:22 PM
grandads76's Avatar
grandads76
Alabama...humidity doesnt dip below 90% very often...we have two seasons: the humid and really humid.
shane
Old Sep 1, 2010 | 10:52 PM
BullyDogJason's Avatar
BullyDogJason
Former Vendor
On interior non load bearing walls i like using steel track, and then infilling with wood studs. gives you the speed of steel and the cheap cost of wood.
If your worried about moisture just use 1/2 OSB and paint it.
AXracer
Oct 9, 2015 09:07 AM
Jerry's red Ford
19
May 9, 2014 08:41 PM
joshofalltrades
Bio-diesel, Propane & Alternative Diesel Engine Fuels
51
Mar 3, 2013 12:21 AM
hucka1a
Nov 30, 2009 10:27 AM
Targus
30
Jul 2, 2008 07:12 PM
