White Smoke Problem Solved
Old Aug 24, 2010 | 08:16 PM
joe doyle's Avatar
joe doyle
My ford dealer is replacing the egr cooler and oil cooler on my 06 6.0 it is two months out of warente but they are going to cover 75% of the cost.I just called ford warente department and explained that i had the same thing happen about a year in a half ago.The next time i will delete egr cooler or install the heavy duty one.Can you get fined if you delete the egr cooler if stopped at a emission check point?Thanks for the help.
Old Aug 24, 2010 | 08:23 PM
rickf92592's Avatar
rickf92592
yes, big time.
Old Aug 24, 2010 | 09:42 PM
Benchwrench's Avatar
Benchwrench
that's still about 8 hundred clams out of pocket.
They should test for HC's and see if it's burning clean instead of seeing if appendages' are still attached.
