front brakes
Old Feb 16, 2003 | 07:25 PM
mvee72's Avatar
mvee72
Angry front brakes
another question about disc brake conversions. I just put a disc brake front end under my 72 f-250 4x4. The brakes dont seem to be working properly. The front end came out of a 74 f-250. Do I need to use the power booster , master cylinder and proportioning valve from the 74 ? My truck was set up with power brakes . It just does'nt feel like they work as good as expected. Thanks. M Vee.
Old Feb 16, 2003 | 07:41 PM
John72_CS's Avatar
John72_CS
front brakes
I'd think you would need the proportioning valve, but I'm not 100% on that. Your booster and master cylinder should be fine. I can't imagine that between 72-74 or so they'd be significantly different. Might want to doublecheck your vacuum too, make sure the booster is getting plenty. Discs should make a big improvement, especially if they're the dual caliper style.
Old Feb 16, 2003 | 09:08 PM
460 Crew's Avatar
460 Crew
front brakes
Yes you need the proportioning valve that is for the disk brakes rather than the drums for sure.
Patrick
1970 F250 CrewCab4x4 460 C6
