Sponsored by: Real Truck
#7 cylinder
Old Aug 23, 2010 | 07:15 PM
aceltx09's Avatar
aceltx09
#7 cylinder
my #7 cylinder is missing like mike tyson at a spelling bee, was running great changed all the plugs, all the boots and springs, I also changed the coil pack in #7 once I figured out which cylinder was missing, it seems to come and go but I'm sure its number 7 put an infared on exhaust manifolds all of them 500 deg. f. except number 7 which is 200 deg f. any suggestions, ideas??????
Old Aug 23, 2010 | 07:51 PM
FORDTUF1's Avatar
FORDTUF1
Okay are you saying it was running great until you changed all this stuff? If so, then I would try moving the wire and/or plug from another cylinder. It wouldn't be the first time there were bad parts out of the box.
Old Aug 23, 2010 | 08:02 PM
aceltx09's Avatar
aceltx09
Thats the weird thing was running fine, I drive a work van so truck only gets driven on weekends, this saturday I installed a flowmaster muffler and all new plugs,boots and springs. I figured out with infared gun 7 cylinder was misfiring changed the coil pack then swapped it out with a working pack when that didn't work. I'm stumped
Old Aug 23, 2010 | 08:58 PM
FORDTUF1's Avatar
FORDTUF1
I'd go ahead and do the wire and plug swap next then. Oh and check the #7 chamber in the flowmaster, it could be backed up. ;-)
Old Aug 23, 2010 | 11:40 PM
Fordfanatic4life's Avatar
Fordfanatic4life
wiring problem ???
can you confirm the wire to #7 is actualy sending a signal to teh cop ?
