Hi,
I'm looking for pictures of the front of a 460 engine, I need to make sure that I'm getting the right brackets for the powersteering and Alternator. Any help would be great thanks!
p.s this motor is going into a 1976 F250 4x4
I believe stock 3 bolt brackets will work. You may have to do a bit of work shimming/adjusting the pulleys to line everything up. The trick is really to get all of the right pulleys when you get your motor. If not you will have a heck of a time matching up pulleys. (Been there done that). I ended up going with an aftermarket set of March pulleys.
