U code front springs
Old Aug 20, 2010 | 11:45 AM
JIMBOEX's Avatar
JIMBOEX
I have a 02 excursion 7.3 4x4 could I use u code springs on the front to level it out or would it be to high? thanks JIMBOEX
Old Aug 20, 2010 | 04:20 PM
Stewart_H's Avatar
Stewart_H
Yes you can. It would raise your front-end right around and inch-and-a-third, maybe a tad more, depending on how worn your original springs are.
That would most likely bring you to almost perfectly level front to back. There is a chance it might make the front-end just a hair higher. It all depends on how worn your back springs are.
Stewart
Old Aug 20, 2010 | 06:19 PM
ribar's Avatar
ribar
I have an '00 Excursion and had an interesting thing happen recently. I broke the primary leaf spring on the front passenger side under heavy braking. I mean it cracked like it was cut with a Sawzall!!!! Reason why I noticed this post was, after replacing the front spring pair on both sides, my Excursion rides about 4" to 6" higher in the front. Sort of reminds me of the Pro Stock cars of the mid 60's. I even had to have the headlights realigned because of the increased height.
The mechanic says they may relax a bit after several months of use. Has anyone else experienced this??? Do they, in fact, eventually relax??? BTW the original springs were made in Mexico, the new ones have a big tag on them that says "Made in USA".
Old Aug 20, 2010 | 06:24 PM
JIMBOEX's Avatar
JIMBOEX
The EX measures 2 inches lower in the front and there is only about 1/2 inch of clearance from the new 03 style bump stop to the spring.I guess that means they are pretty weak?The springs that I was looking at were on a 03 f250 for 3 years before a lift kit was installed and the pair is only $50.00 is it worth a try? thanks JIMBOEX
Old Aug 20, 2010 | 08:59 PM
Stewart_H's Avatar
Stewart_H
Grab 'em and don't look back.
Well worth it.
Stewart
Old Aug 21, 2010 | 01:57 AM
shortboxd's Avatar
shortboxd
I had 'U' codes on my first Excursion, a 2000 Limited 7.3 4x4. The truck was perfectly level after this mod, and gave a little over 2 1/2" to the bump stops. I did nothing with the rear springs on this truck other than Fireston Ride Rites.
I have heard of a few installs where a V code was used on the left side and a U on the right to keep things level up front; I never saw the imbalance or necessity on my 2000; it's possible I may have seen it had I kept the truck long enough to see the new springs settle. Unfortunately, that Ex went bye-bye due to job loss, so I never knew.
I am considering the U and V spring option with the 02 we presently own.
Stewart_H
Oct 24, 2017 11:57 AM
drwecki
Mar 27, 2017 06:53 AM
Sherman Manley
May 24, 2016 12:54 AM
Areyouliving
Jan 29, 2016 05:20 PM
Stewart_H
Nov 3, 2008 07:47 PM
