Heater control light
Old Aug 19, 2010 | 06:45 PM
Colorado Ford Guy's Avatar
Colorado Ford Guy
Guys,
Where is the light bulb for the heater control and how do I change it??
Old Aug 20, 2010 | 09:21 AM
Franklin2's Avatar
Franklin2
I am pretty sure it's plugged into the unit itself. You will have to pull the dash apart, pull the unit out a little bit, and replace the bulb.
Old Aug 20, 2010 | 04:24 PM
Colorado Ford Guy
Dave, thanks for your reply. But guess what. The unit does not pull out. If you take the screws out, it is mounted behind the dash, so it goes toward the firewall. The ash tray is below it, so you can't see anything.Even if you take the ashtray out the plastic dash still hides it. I'm not getting anywhere.
Old Aug 20, 2010 | 04:40 PM
Fordzilla80's Avatar
Fordzilla80
You're gonna have to pull the dash pad off,or remove the radio to gain access to the back of it.When I did it,removing the bulb socket was easy,but putting it back in was another story.I suggest getting a mirror and flashlight and using those to locate it so you know what you're looking for and it's location.It's directly in the center on the back of the control panel,as Franklin said.
Old Aug 20, 2010 | 05:13 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
Old Aug 21, 2010 | 08:47 AM
Colorado Ford Guy
Thanks guys. The photo really helps. It's wonderful to be a part of this forum. The knowledge base here is amazing.
I'll do the bulb change when I install my original Ford radio and Ford radio installation kit, which I found on ebay. The install kit came with door speakers, wiring, brackets, and instruction sheet. All in a Ford box.
