Heater problem
Old Aug 19, 2010 | 06:03 AM
ltl_jrw's Avatar
ltl_jrw
Heater problem
I am in Gillette Wyoming working pipeline for the next few months and it already has gotten down to 47* and I turned on my heater an no heat. After checking things out I found the electronic blend door control is not working, if I tap on it it will work and switch to heat but if I switch back to AC and back to heat it will stay on AC. Question is how do you get the control out so I can replace it.
Old Aug 19, 2010 | 07:12 AM
riverrat41's Avatar
riverrat41
Might want to check them vacuum hoses as well while you are checking.
Old Aug 19, 2010 | 07:35 AM
Kwikkordead's Avatar
Kwikkordead
IIRC there are a couple of phillips head screws, one on each end of the motor that secures it to the body of the heater.
They come out the top so you have to reach up there and feel around for them.
Use a very stubby phillips screwdriver or a phillips head bit on a ratchet head.
Old Aug 19, 2010 | 08:30 PM
ltl_jrw's Avatar
ltl_jrw
All the vacum hoses seem to be doing the right thing, I can switch from dash vents to floor and on AC it will do all the right thing.
Old Aug 19, 2010 | 08:33 PM
ltl_jrw's Avatar
ltl_jrw
Thanks, I will see if I can get the little booges out. Do you think the door might be sticking and if so how do you get to the door?
Old Aug 20, 2010 | 05:23 AM
ltl_jrw's Avatar
ltl_jrw
Anyone?????????????????
Samorkand
WTB - Parts & other
Nov 21, 2012 01:58 PM
Samorkand
Modular V10 (6.8l)
16
Jun 21, 2012 12:01 PM
usmcdaveII
Apr 24, 2010 01:57 PM
armynavyguy
Modular V10 (6.8l)
18
Mar 6, 2008 06:41 PM
mark-in-wyoming
May 15, 2006 10:07 AM
