DP Tuner Control location?
Old Aug 18, 2010 | 11:21 AM
F-250 Super Duty's Avatar
F-250 Super Duty
I already know most will say it's personal preference but I'd like some insight.
I have the F5 in the cart with the round controller ready to push the buy button. I have a three pod pillar and was torn between putting in a four or getting the mount on top of the steering column for the controller.
Who has what? Which one do you like? Is there any problems with the one on the column, like seeing the wires or the back of the guage etc?
I like the idea of the four pillar mount but that takes away adding a fuel pressure gauge or HPOP gauge later....... but then controller can be move later too.....
Any thoughts?
Old Aug 18, 2010 | 11:42 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Got mine in the pillar. Easy to get to if I need to go to 120r
Old Aug 18, 2010 | 11:48 AM
gasgrunt88's Avatar
gasgrunt88
Mine is on the pillar. Easy to get to as its right under my gauges.
Old Aug 18, 2010 | 11:49 AM
Stewart_H's Avatar
Stewart_H
I used Jody's JMS mount and installed my changer here:
Stewart
Old Aug 18, 2010 | 11:57 AM
cvdenson's Avatar
cvdenson
I mounted my F5 in the ashtray. Was going for stealth.
Old Aug 18, 2010 | 12:11 PM
kccatpower's Avatar
kccatpower
Old Aug 18, 2010 | 12:19 PM
bulla's Avatar
bulla
[quote=Stewart_H;9232041]I used Jody's JMS mount and installed my changer here:
Stewart, I know this is off the subject but do you or anyone else know what those vents are for right below the DP Tuner switch? Me and Rick were noticing in my truck I had them and he didnt. Our trucks are both the same year and make cc drw lariet. Just curious?
Old Aug 18, 2010 | 12:59 PM
Mark250's Avatar
Mark250
Made a bracket for mine using the mount screws for my brake controller, so it sits just right of the brake controller. Didn't want to cut any holes in the dash.
Old Aug 18, 2010 | 01:34 PM
Stewart_H's Avatar
Stewart_H
They are there so you can mount an aftermarket tweeter.
I really have no clue. Asthetic reasons?
Stewart
Old Aug 18, 2010 | 01:47 PM
bama29fan's Avatar
bama29fan
Stewart
where is the dinger/door chime...could it be to make it more audible?
Old Aug 18, 2010 | 01:59 PM
Stewart_H's Avatar
Stewart_H
Dunno, I'll have to check.
Stewart
Old Aug 18, 2010 | 02:08 PM
Bonanza35's Avatar
Bonanza35
There is a mount that goes around one of your three gauges that allows you to put the square mount head on either side of you gauge. It looks great the buttons are right there and you don't need the four gauge pillar. I have it on mine and really like it. I didn't want to cut a hole in the dash, and I mit want that forth hole for a gauge for something else. Call jody or james, I got mine from John Woods when I put my trans in. I don't know how to post pictures or I would show you, God Bless, Chet
Old Aug 18, 2010 | 02:28 PM
F-250 Super Duty
Originally Posted by kccatpower
I thought of that option also, looks good and didn't know if there was room behind the dash. Now I see there is.
Old Aug 18, 2010 | 03:05 PM
USAF CCM's Avatar
USAF CCM
This is where mine is too! Since I have no-start and the controller is almost out of "line-of-sight", it gives me some peace of mind when leaving vehicle somewhere other than my driveway.....and even in my driveway!
This location allows for very easy switching of tunes too, just incase I run into a pokey driver!
Old Aug 18, 2010 | 04:12 PM
kccatpower's Avatar
kccatpower
i like this location, for me i can put it in no start, remove the key in one motion.
