cant pull out VSS
Old Aug 18, 2010 | 07:37 AM
kupiec20's Avatar
kupiec20
cant pull out VSS
any tricks? i took the bolt out and the vss will twist a bit but i cant pull it out. how much force can i use?
thanks
Old Aug 18, 2010 | 07:49 AM
ccarrier's Avatar
ccarrier
have you sprayed anything on it? too loosen it up.
Old Aug 18, 2010 | 07:56 AM
kupiec20's Avatar
kupiec20
no because it twist side to side! should i spray it?
Old Aug 18, 2010 | 09:09 AM
superduty4x4's Avatar
superduty4x4
It should just pop out, there is an O-ring on it that makes it pretty snug in there.
Old Aug 18, 2010 | 09:47 AM
strokersace's Avatar
strokersace
In theory it should just pop out, but that's not always the case. Ever tried to pop out a CPS that's been in a motor for a long time? It's dang near impossible!! I've broke an old CPS trying. Same with the VSS. Broke one trying like crazy to get it out.
It had been in the rear end since 1993 (this was last summer) and nothing I could do allowed it to pop out. It'd twist side to side just like the op. I tried to drill into it and easy-out it, but being a magnet, it's too hard. I ended up pulling the back cover and using a long screwdriver to pry it out from the inside.
Old Aug 18, 2010 | 09:58 AM
superduty4x4
You must have forgot to say the magic phrase...
"COME OUT OF THERE YOU MISERABLE F***ING CROSS-EYED SUNNY-BEACHIN PIECE OF CHIT!!!"
Old Aug 18, 2010 | 10:02 AM
strokersace
LOL!! Nah, tried that and still didn't work. I even used some other phrases that involved alot more adjectives and those didn't help either!
Old Aug 18, 2010 | 10:27 AM
superduty4x4
Did you throw a wrench? Hit your head on something? There must be one important step you forgot
Old Aug 18, 2010 | 10:35 AM
Brown Falcon's Avatar
Brown Falcon
You probably didn't let your hand slip off and bust open your knuckles on something sharp... that works every time!
Old Aug 18, 2010 | 10:41 AM
strokersace
Yep, all of that too! And was laying in a sticker patch in my parents driveway, in the dark, with a crappity azz flashlight. Oh the memories!
