blow bye/ smoke out of oil fill cap
Old 08-17-2010, 05:32 PM
FORD E-150's Avatar
FORD E-150
FORD E-150 is offline
Post blow bye/ smoke out of oil fill cap
hello i have a 1992 ford e -150 van 5.0 302
it does not burn oil but i always see smoke like exhust comeing out of the oil filler cap can any body tell if they had same problems as i and what to do about it it runs good i also get pinging to would that be the caouse of it i wonder
Old 08-20-2010, 11:29 AM
Lightningjr's Avatar
Lightningjr
Lightningjr is offline
Have you done anything to it before it started doing this? For the pinging I would check the timing. How bad is the smoke comming out? Some is acceptable
Old 08-20-2010, 01:40 PM
Beanscoot's Avatar
Beanscoot
Beanscoot is offline
Inoperative PCV system?
Old 09-02-2010, 01:03 PM
shastalynk's Avatar
shastalynk
shastalynk is offline
Perhaps...
I'm still learning about the whole emissions stuff, BUT, I have learned that if your oilfiller is smoking, it could be because your EGR valve isn't working. The vapors in your intake manifold are being circulated, there for they come out of your oilfiller cap. You can take your EGR valve off and unstick, just be careful not to damage the diaphram and lube the shaft...
Old 09-03-2010, 10:24 PM
Beanscoot's Avatar
Beanscoot
PCV vs EGR
"I have learned that if your oilfiller is smoking, it could be because your EGR valve isn't working."
Actually the EGR system connects the exhaust system to the intake system, and is not connected to the crankcase ventilation system. The crankcase system is the volume around the crankshaft, rods etc. as well as above the valve rocker arms and underneath the intake manifold.
So a faulty EGR will not cause "smoke" or fumes to be driven out of the oil filler cap.
Old 09-05-2010, 08:59 AM
bashby's Avatar
bashby
bashby is offline
pull the pcv valve out of the valve cover and see if it is sucking air, it should be. If the pcv valve is bad or the pcv passage is clogged it wont pull enough air through the crankcase to overcome the blowby. If the pcv is working and you still get smoke from the oil filler then you have excessive blowby (rings worn out).
dudef150
10-09-2014 10:18 AM
rustoleum82
02-25-2014 02:41 PM
OldTimerDually
09-23-2013 12:46 PM
cutlass
09-21-2012 01:02 AM
bigtexan99
01-18-2007 09:32 PM
Quick Reply: blow bye/ smoke out of oil fill cap
