Oil & Lubrication
Oil analysis back
Old Feb 15, 2003 | 07:53 PM
jagabom's Avatar
jagabom
Oil analysis back
498 kM or ~ 310 m. Factory fill of what I guess is 5W-30. 1st oil change. New car.
2.2 ecotec GM Sunfire
FE 42
Cr 1
Mo 48
Al 6
Cu 13
Pb 3
Sn 7
Si 39
Na 11
Zn 883
K 14
Ni 2
No antifreeze, fuel or water.
What do you think? I havn't a clue what any of the numbers mean.
Old Feb 15, 2003 | 09:07 PM
Flash's Avatar
Flash
Oil analysis back
There is something VERY wrong here. I really suspect a bad analysis. First, the FE is iron.Granted it is a new engine but 42 ppm is high. Also the SI jumps off the page and says something here is wrong as well. SI= silicone(read dirt). I would check the car to make sure it has an air filter element in the filter box as 39 ppm is off the scale for 310 miles. I would suggest that you change the oil again after 1000 miles and have it analysised again. I don't think the report is accurate.
Old Feb 15, 2003 | 10:03 PM
jimandmandy's Avatar
jimandmandy
Oil analysis back
I wouldn't worry. A test on the next oil change would be more informative. Mass produced engines are not assembled in a "clean room" environment, so there may be some casting sand and machining particles still left behind, hence the iron and silicon. The moly could be from the factory-fill oil or from the new piston rings.
Jim
Old Feb 16, 2003 | 12:28 PM
skoop's Avatar
skoop
Oil analysis back
This is totally normal. Iron, copper, lead, and tin are high because new metal surfaces are mating together. The silicone is evaporation of the sealants used on the gaskets. GM products are known to be notoriously high in copper values in oil analyses, too. Copper, lead, and tin are metals in the bearings.
Don't worry about it.
Change your oil again at 1000 miles and test. Numbers will drop. Eventually you will see the values stabilize, particularly if you are careful to change your oil and filter scrupulously, depending on your driving habits and climate in which you drive.
Old Feb 16, 2003 | 01:55 PM
Flash's Avatar
Flash
Oil analysis back
So that you may have something to compare your analysis with another, here is a new 2.2 ecotec with factory fill. Miles on oil 5056. Only items with value are listed otherwise is zero.
Copper 8
Iron 95
Chromium 1
Lead 1
Aluminum 3
Silicon 9
Tin 2
Moly 12
Zinc 842
