Oil light staying on
Old Aug 17, 2010 | 11:34 AM
66crawler's Avatar
66crawler
Do I need a new oil pressure sender? it actually gets brighter when you rev the motor and the pressure comes up.
Old Aug 17, 2010 | 01:13 PM
Flyn66dtmn's Avatar
Flyn66dtmn
if it was working fine until lately and started doing this it would be my guess that the sender went to heaven.oil pressure in the sensor is what turns off the light as it breaks the connection. Dutch
Old Aug 17, 2010 | 01:26 PM
66crawler's Avatar
66crawler
Well I just got the truck last week so I think ill just get a oil pressure gauge when I can.
Old Aug 17, 2010 | 02:21 PM
StevenhF100's Avatar
StevenhF100
Your 66 could have two sending units and two wires for oil pressure. One for the light and one for the factory gauge. Make sure you have the correct wire connected to the light. Connection could be switched at the dash or connected to the wrong sending unit. The sending unit for the light should be a small round unit, the sending unit for the gauge is a larger (about 2") cylinder type. Our if you only have one sending unit, it could be the one for the gauge. Hope that helps.
Old Aug 17, 2010 | 03:16 PM
baracade's Avatar
baracade
I do not trust the idiot light, so I installed an aftermarket oil pressure gauge, 50lbs @ idle when engine is cold.
Old Aug 17, 2010 | 03:28 PM
66crawler's Avatar
66crawler
Yeah i dont have a factory gauge, the only factory gauge that works is the speedo and the oil light, missing the fuel gauge part of the cluster. It dose have 3 aftermarket gauges hanging from the bottom oud the dash but only the water temp is hooked up. It runs a little warm but I need a fan shroud. I have the oil gauge, can i buy just the tubing and fittings from like auto zone or checkers?
Old Aug 17, 2010 | 04:13 PM
baracade's Avatar
baracade
Newer type oil pressure guages do not use tubing, the sending unit hooks up to the guage with 1 wire, no hot oil in the cab! Check your aftermarket guage to see what type of hookup it is, I would not use it if has to have an oil line ran to it. I would pony up for a new guage!
Old Aug 17, 2010 | 04:35 PM
66crawler's Avatar
66crawler
Yeah those other gauges arent cheap either, ive never had a problem with the oil line leaking and this is the first time im hearing of the wire type gauge.
Old Aug 17, 2010 | 04:58 PM
camperspecial65's Avatar
camperspecial65
the original type of wiring on trucks that had the standard oil idiot light and those with the optional oil pressure gauge had two totally different type of connections...totally idiot proof...the standard one had a blade connector that slips at a 90 degree angle over the end contact of it. The larger can used with the gause has a 90 degree molded rubber elbow type push on connector...exactly like the brake light switch....its wire is red and white as i recall...
- cs65
Old Aug 17, 2010 | 05:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The oil sending unit for the idiot light was notorious for leaking oil. When that occured, the idiot light on the dash came on...and stayed on.
The other problem was, the switch got gummed up inside, so the same thing occured.
Ford used the same fracatta idiot light sending unit from 1956 thru 1966 on just about everything.
B6A9278B .. Oil Sending Unit-Use with Warning (Idiot) Light (Motorcraft SW667) / Obsolete
E4ZZ9278A (replaced: C9ZZ9278A; C7ZZ9278A; B7T9278A) .. Oil Sending Unit-Use with Oil Pressure Gauge (Motorcraft SW1457B) / Available from Ford.
Old Aug 17, 2010 | 05:19 PM
66crawler's Avatar
66crawler
Where would it be located on a 390? I dont have exp with fe motors.
Old Aug 17, 2010 | 05:43 PM
StevenhF100
- cs65
Nothings totally idiot proof. The last parts truck I bought, the guy had the ignition switch go out so he wired in a house light switch. I've seen them crossed.
The sender is located on the oil filter adapter behind the oil filter.
Old Aug 17, 2010 | 05:56 PM
66crawler's Avatar
66crawler
Ok thank you.
Old Aug 17, 2010 | 07:12 PM
Big Daddy T's Avatar
Big Daddy T
the sender for the oil light is on the filter head driver side front of the engine
Old Aug 18, 2010 | 10:59 AM
StevenhF100
More likely cause is a newer motor with a gauge sender only was installed and the oil presser light wire from the truck was hooked to this incorrect sender. If so, a new oil pressure light sender will fix the problem.
