I have an 82 F100. The parking lights and the dash lights quit working all of a sudden. Break lights, turn signals, and headlights work fine. I checked the fuses, and they are fine as well. Anyone have any suggestions as to where to look next? This truck has low miles, and the wiring looks to be untouched for the most part. Are there any fuseable links that I may be missing? I find it odd that both the parking and dash cluster lights quit working together, as they are fused separately.
If I recall, the park lights, side marker lights, and dash lights all get power from the same wire, but based on what you say, I guess it splits off to two circuits. You might check for any bad grounds.
Also clean and make sure the large "(" shaped wiring harness under the hood below the brake booster is connected securely. I've had a loose one cause my brake and turn functions to not work at the rear of my truck. Not sure if it could cause your dash lights to go out, but it's worth a try. If anything, you'll get better electrical contact after cleaning it.
There may be a chance it could be the headlight switch, since I've seen a bad one cause some pretty odd problems; when mine went out, the headlights didn't work but everything else did, and on my uncle's 70s Chevrolet, his headlights worked but nothing else did (dash lights, parking lights, etc.)
I was thinking headlight switch too. I will check the connection you mentioned as well. Thanks for the tips!
Back when my headlight switch was going out, during the time it was finally frying itself, it was causing a 17 volt overcharge. The voltage regulator was apparently trying to compensate for the huge short circuit. It blew out both of my headlights.....which were Sylvania Silverstars...
Ouch! I've never heard of anything like that before.
Yea it was a first for me. I'd had charging system problems in the past due to bad regulators and a dead alternator, but that 17V overcharge freaked me out lol. We had went to be with a friend that had gotten stranded on the way to our house, and everything was fine til we parked. I noticed the aftermarket voltmeter I had put in was pegged...we tried to drive it home, and for a very short time, boy were those headlights bright. LOL
I had one guy tell me it was the regulator, but there's two reasons I didn't believe him. One, my uncle said it was the switch, and he's been working on vehicles for 50 years...the other guy was in his 30s. Second, the overcharging stopped when the switch blew.
Well, that makes sense. On my truck, it would make sense for the switch to be bad because the parking and dash lights just stopped working all of a sudden. No one has messed with wiring or anything, so I'll pull the switch and check it next.
A tip, in order to remove the headlight switch ****, you have to reach up under the dash and press the small button on the bottom of the switch. It takes a little fiddling, but be patient and it will come out. Putting it back on is just a matter of pushing it back into the switch til you feel it click.
I hope you can get this fixed soon, it's always a pain when stuff goes bad.
Ok, thanks. Sounds like the same setup as the 69 F100 I used to have.
Welp, it was the headlight switch. If you push the switch in a little with the headlights on, the parking lights work. So, off to get a new switch I go!
