saving the trans
Old Aug 15, 2010 | 06:24 PM
crazer42's Avatar
crazer42
saving the trans
i just wanted to know if there was anything in daily driving that can hurt an old trans, is it hard on the trans to really get on it? i mean from a stop to hit the go pedal?
i justfeel like my trans is on its way out, sometimes it will shift early, and under fast acceleration it will slam into gear and shake the whole truck, just wanted to know if there was anyway to prolong life
the temps usually run 150-160
in traffic 175 but it is pretty hot here in florida
Old Aug 15, 2010 | 06:29 PM
KH85's Avatar
KH85
Drive it like an old man! And keep the temps as low as possible. Id highly recomend and after market trany cooler like the Tru-Cool Max or a 6.0 cooler if you dont already have one. But the bad news is if its on its way out then your prob only goin to be able to prolong it for a while, esecially if you tow. I'd get ready for a trany rebuild/replace!
Old Aug 15, 2010 | 07:19 PM
Franko72's Avatar
Franko72
Molon Labe
Just go easy on it. thats about all you can do.
I dumped a bottle of Lucas stop slip in mine to prolong its death, not sure if it did anything....
Old Aug 15, 2010 | 07:55 PM
rbaker6336's Avatar
rbaker6336
Does it do it in all tunes and stock setting?
Old Aug 15, 2010 | 09:01 PM
erbilabuc's Avatar
erbilabuc
have you tried changing the fluid? Im a new PS-D owner and had tranny issues from the get go and just changing the fluid and filter helped a lot.
Old Aug 16, 2010 | 07:08 AM
wolfrace's Avatar
wolfrace
You like apples?
Hard shifts are better than thoughs long grinding stock shifts.......................... your temps are good, I would agree with the fresh fluid........................ Mobil 1 ATF SYN
Old Aug 16, 2010 | 07:50 AM
deemac's Avatar
deemac
It sounds to me like its your torque converter. The stock converters cant handle the power, so when you put power to them the stall speed is faster, then when they lock up it jolts the truck, kind of like slamming into gear. A better torque converter might do some good.
