efi cam install
Old Aug 15, 2010 | 04:18 PM
9D1's Avatar
9D1
efi cam install
preparing for a cam install next weekend and have a couple questions. im a bit confused about the timing gears. i want the cam straight up, its the crane 503901, is this cam ground "straight up"? without the factory 4 degrees retard? if so then the timing gears would go dot to dot. just need a little input on this. its in a 91. also from the efi guys, any issues with the knock sensor and metal gears? will be running cloyes set. thanks for the help!!!
Old Aug 15, 2010 | 10:39 PM
200000+F150's Avatar
200000+F150
The difference is in the gears, not the cam itself. The metal gears should be straight up, the fiber ones retarded. Just built mine with the metal ones. I haven't driven it much yet due to trans issues, but no issues that I can see. I used this same cam and seems mostly OK, but idle vacuum is a little low (14-15in.) Seems sluggish right off the line but I'm also having fuel pressure issues that I need to correct before I can say more. BTW, I also have the ridiculous 2.79 rear gears.
