INITIAL STARTUP
Old Aug 15, 2010 | 09:56 AM
NSTAG8R's Avatar
NSTAG8R
INITIAL STARTUP
recently rebuilt my 7.3. tried to start it saturday, unsuccesfully. hooked my supertuner programer up and got code p0603.
fords shop manual p0603 =
Possible causes:
<DIR><DIR>Battery or PCM has been disconnected.
Battery cables loose or poor connection.
Battery discharged.
Open in KAPWR circuit.
Blown fuse.
PCM.
</DIR></DIR>Check for other codes. Key on, engine off. Clear DTCs. Cycle key off, then on. Perform retrieve Continuous DTCs
we checked all the 5 amp fuses - o.k.
the batteries had been out since the end of may. could it had lost all the pcm memory that contols starting.
also is there any initial priming procedures that should be performed that may allow it to be started.
could i possibly install the lowest supertuner performance program in hopes of restoring some type of memory to the computer to allow it to start.
any other help that i may not know about or can find will be very helpfull.
Old Aug 15, 2010 | 11:19 AM
twags6's Avatar
twags6
The truck wont loose memory from disconnected batteries. All the programming is permanent. How's the charge on the batteries? You might not have enough voltage while cranking to allow the truck to start. 10.5 volts is the minimum required for the injectors to fire. Charge them up overnight or try hooking a jump vehicle to the truck to get it going. It might run a little crappy after being down that long.
Old Aug 15, 2010 | 11:24 AM
NSTAG8R's Avatar
NSTAG8R
took them both to autozone one was charged up the other was bad. did take the bettery out of my dodge as a second.
will charge them both if the jump vehicle does not work.
Old Aug 15, 2010 | 11:56 AM
twags6's Avatar
twags6
If one was bad, both should be replaced. Leaving an old batt in with a new one will kill the new one in a shorter time. Keep us posted.
Old Aug 19, 2010 | 07:34 AM
NSTAG8R's Avatar
NSTAG8R
ITS LIVES !!!!!!
ELEVEN WORDS THAT WILL HELP THE NEXT PERSON AS FAR AS THE HPOP GOES:
PRIME, CRANK, PRIME, CRANK, PRIME, CRANK, PRIME, CRANK, CRANK, CRANK, CRANK!!!
WHAT IT TAKES TO REBUILD A 7.3 L INTERNATIONAL
HEAD WORK - $560.00
BLOCK WORK/SLEEVED CYLINDER - $1061.00
VARIOUS TOOLS, ENGINE STAND, EXPLICATE INSTRUCTIONS - $600.00
HELP FROM INTERNET FORUMS - PRICELESS
THANKS EVERYONE!!!!!
Old Aug 19, 2010 | 07:42 AM
Kwikkordead's Avatar
Kwikkordead
It's a good feeling when it fires up, isn't it.
Those oil rails hold a fair amount of oil.
My engine took three of these per rail to fill up the HPO rail.
And filling the reservoir like this enabled the engine to start with a very minimum of excess cranking.
bekko
Nov 1, 2013 02:22 AM
megawatt00
52
Sep 25, 2012 06:01 PM
RANGER589
18
Jun 3, 2011 10:03 AM
bigwilliejoe
32
May 23, 2010 06:28 PM
nghtrgr
May 22, 2009 02:07 PM
