78 Auto Steering Column Swap Help
Old Aug 14, 2010 | 09:20 PM
TNVOL's Avatar
TNVOL
I'm switching in an original auto tilt column. I was told this was a 20 min job, but with my luck it never works out that way. Got the old one out and the new one in. The problem is getting the shift rod hooked back up. Any tips to getting the bushing back in good and tight. I've tried to knock it in with a hammer but theres not much room to work with. Also tried squeezing it in by using a c-clamp. Any tips? Should I go ahead and replace the bushing. Thanks.
Old Aug 14, 2010 | 09:26 PM
steponit's Avatar
steponit
Long nosed vice grips or pliers works.
Use a little vaseline on it
offroadbronco's Avatar
offroadbronco
Mine usually pop back in with the help of some pliers.
Its easier to do w/ the column out and then hook up the trans end once in place.
