2005 Excursion and 2011 F-250 Take Offs
Old 08-22-2010, 08:52 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Originally Posted by Monsta
Listen, all F350 duallys use spacers up front.
Yes OEM steel ones.
Old 08-23-2010, 07:00 PM
Ben FORD's Avatar
Ben FORD
Ben FORD is offline
I ordered a steel set from Fred at wheeladapters.com. I will post some pics when I'm all set-up. Thanks
Old 03-13-2011, 04:11 PM
sean23johnson's Avatar
sean23johnson
sean23johnson is offline
Bringing back from the dead. Any pics??? I am interested in newer SD wheels on my 99.
Old 03-13-2011, 06:10 PM
Ben FORD's Avatar
Ben FORD
Ben FORD is offline
We got the adapters from Fred, added a new springs on the front for a 2" lift and added air bag on the rear. We had to grind about 1/4" off the front studs.
Old 03-13-2011, 06:17 PM
sean23johnson
Wow that looks really good!!! Do the tires stick put past the fenders? Did you get 2" or 2.5" spacers? Also what size tires are you running? Sorry for all the questions, just gathering info.
Old 03-13-2011, 06:23 PM
Ben FORD's Avatar
Ben FORD
Ben FORD is offline
Thanks - we got the 2" spacers. With 2" spacers the tires do not stick out any further than the stock tires/wheels. The tires are stock tires for a 20" rim 2011 F-250.
Old 03-14-2011, 08:43 AM
MoreBoostPlease's Avatar
MoreBoostPlease
MoreBoostPlease is offline
Your Ex looks perfect! What size are the tires? Also, what lift did you go with?
Old 03-15-2011, 12:43 AM
bigrayq's Avatar
bigrayq
bigrayq is offline
Harley f-250 20's with no lift, wheel adapters from Fred at Wheeladapters.com
Old 07-09-2011, 09:07 AM
Fordfanatic69's Avatar
Fordfanatic69
Fordfanatic69 is offline
4wd Low
Is everybody having to grind down the factory studs
Old 02-11-2012, 11:22 AM
Ben FORD's Avatar
Ben FORD
Ben FORD is offline
I had to grind down the front wheel studs about 1/8th - 1/4th inch. Update - Just checked the spacer torque for the second time since putting these adapters on and no torque was lost. We also ended up having new blocks made for the back so that there wasn't so much air in the air bags. The ride is much better with so swaying.
Old 04-29-2013, 07:39 PM
High Intentions's Avatar
High Intentions
High Intentions is offline
Mod Specialist ;)
You just have to grind down the fronts only and not the rear studs?
Old 10-06-2013, 06:45 PM
xplodn's Avatar
xplodn
xplodn is offline
Bringing it back from the dead. I picked up a 2005+ OEM 18's today for a steal. It seems that the Coming Soon page website is down where has anyone found good spacers lately?
Here is a set of hub Centric ones-
Ford 8x170 2.00" Wheel Spacers : Amazon.com : Automotive Ford 8x170 2.00" Wheel Spacers : Amazon.com : Automotive
  #28
Old 10-07-2013, 01:51 PM
DavenTn's Avatar
DavenTn
DavenTn is offline
Here is a set of hub Centric ones- Ford 8x170 2.00" Wheel Spacers : Amazon.com : Automotive
They look fine to me. They're aluminum and I noticed the price is for 2 ... so 4 = 480.00. If it were me, it's important to know they're made/machined from billet 6160 T-6 and I did not see that in the description. I agree... Aluminum adds less unsprung weight to the suspension but steel is more forgiving. However I see no reason why these spacers would be just fine and dandy though.
I will say without reservation, there are lots of horror stories with Aluminum spacers. FYI... anytime aluminum and dissimilar metals are combined/bolted together, use a inhibiting compound. I like NO-OX special ID and it has tons of other uses as well.
  #29
Old 10-07-2013, 02:29 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
I used the "cheap" ebay spacers that ARE hubcentric and they are perfect. Personally I think it's a waste to buy the exact same thing for more money but others disagree. My 2 cents.
The following users liked this post:
  #30
Old 10-07-2013, 04:21 PM
ycis's Avatar
ycis
ycis is offline
that black ex looks sick! love it
I think someone did the math in another thread about hub vs lug centric....and that you had very little to worry about in "shearing off" 8 individual grade 8 bolts....no matter how much you tow.
Quick Reply: 2005 Excursion and 2011 F-250 Take Offs
