2006 explorer transmission slipping
Old Aug 14, 2010 | 05:39 PM
royisrael's Avatar
royisrael
I have a 2006 explorer that the engine revs before transmission changes into next gear! It seems to be in lower gears more and when accelerating from a stop! On another forum i found a quick blurb about valve body gaskets. Is this the problem and how can i verify?
Thanks,
CLUELESS IN KEIZER!
Old Aug 15, 2010 | 04:09 PM
Moto Mel's Avatar
Moto Mel
Thanks,
CLUELESS IN KEIZER!
It is a job for those with experience as the valve body has to be removed for inspection of the gaskets and if you lose or misplace the little ***** in the valve body you will have it towed to a transmission shop. The other way is to take it to a transmission shop that can be trusted (HA!) and have them run an operational test on the trans.
Good luck with it.
Old Aug 19, 2010 | 09:46 PM
djwhoo2005's Avatar
djwhoo2005
well...? whats up? did you get it fixed? my 02 v8 X slips too.. im gonna get a tranny flush and c if that works.
tfink3
Jun 4, 2017 10:56 AM
Neo01
Nov 20, 2016 09:29 PM
chuckj5
Mar 17, 2016 08:10 PM
EffieTrucker
Oct 13, 2015 07:57 AM
71LTD390
Apr 27, 2012 07:00 PM
