Cluster not working.Please Help
Old Aug 14, 2010 | 02:31 PM
neilfromatl's Avatar
neilfromatl
Just bought a 02 LTD but the guages are not working.The previous owner swapped out the cluster but that was not the cure.I have checked all the fuses and power to the cluster and still a no go.I also think the O/D is not working.(have repaired chafted O/D wire)
Any ideas
Old Aug 14, 2010 | 03:49 PM
Monsta's Avatar
Monsta
Sit. Stay.
Wait...so you know for a fact that you have power going into the cluster?
Old Aug 14, 2010 | 04:16 PM
neilfromatl
Yeh,the 2 outer bottom pins on the plugs on the back of the cluster have power.
Old Aug 15, 2010 | 11:13 AM
neilfromatl
Any ideas?
Old Aug 15, 2010 | 11:31 PM
Shepherd2's Avatar
Shepherd2
With the cluster unplugged and key on you should have at least 10 volts at the LG/OG, BK/LG, BK/PK, and RD/YE wires. On the same connector you should have less than 5 ohms resistance to ground on the PK/OG and BK wires.
Old Aug 22, 2010 | 01:33 PM
neilfromatl
Is a combination of the wires in all 3 plugs on the back of the cluster?or one plug
Thanks
Old Aug 22, 2010 | 05:12 PM
Shepherd2's Avatar
Shepherd2
If I translated your question right, these wires are all on the same connector.
