Back-Up Sensors
Old Aug 13, 2010 | 08:02 PM
jcobb124's Avatar
jcobb124
Back-Up Sensors
My back up sensor shows "off" all of the time, and according to my manual there is a fault. Does anyone of any quick and easy or obvious fixes?
Old Aug 13, 2010 | 09:07 PM
Shepherd2's Avatar
Shepherd2
If you have a scanner it will tell you which sensor is bad or if it's something else. You can check the wiring for damage or corrosion but other than that your going to be chasing your tail with a code.
Old Aug 13, 2010 | 09:10 PM
jcobb124's Avatar
jcobb124
No scanner... I have a semi-donor Ex, is there a module for the sensors?
Old Aug 13, 2010 | 09:21 PM
Shepherd2's Avatar
Shepherd2
There's a module, I think it's located behind the jack compartment. It's a 26 pin connector if that helps.
