Yet another newbe AC thread
Old Aug 12, 2010 | 06:35 PM
jmgekeler's Avatar
jmgekeler
Hi All-
The ac is blowing warm air. So I opened the hood and checked that the compressor clutch was spinning, which it was not. So I jumped the low pressure switch back by the evaporator, and the clutch kicked in. I hooked up a bottle of 134. However, no refrigerant ever left the bottle, even after about 15 minutes.
I checked the service valve and when I pressed it in to see if it was stuck I could see refrigerant escaping.
I then turned off the AC and when I turned it back on the compressor was no longer turning. The LP pressure switch was still jumped.
It seems like there may be a couple of problems. One, the compressor spinning and then no longer spinning once I "restarted" the AC, and two, the system not taking any refrigerant.
Any help would be great!!
Thanks- Jason
Old Aug 13, 2010 | 08:06 AM
Neal 97 250's Avatar
Neal 97 250
Check the plugs on top of the compressor. They get old and loose. You may have to clean them up and tighten them up a tad with pliers.
Happened to mine. Wiggle the wires and it went off and on.
