not starting
Old Aug 12, 2010 | 04:33 PM
chillmiller's Avatar
chillmiller
not starting
i turn the key solenoid just clicks
replaced the solenoid
and starter
already....
battery is good
no burnt wires... that i can see...
i dunno started just fine 10 minutes befor....
Old Aug 12, 2010 | 04:40 PM
Slip ford man's Avatar
Slip ford man
When was the starter replaced, was it a new rebuild?
Old Aug 12, 2010 | 04:55 PM
lew52's Avatar
lew52
You need to lick the solinoid , your tongue needs to touch both posts when trying to start it....
chillmiller
just before this post rebuilt tested passed
Old Aug 12, 2010 | 04:56 PM
chillmiller
tryed that.... just didnt work
Old Aug 12, 2010 | 06:52 PM
Slip ford man
Well it sounds like the starter may need to be load tested again...I replaced mine the other day, the old one passed the first load test, but failed the same test the second time he did it. Put a new re-build in from Auto Zone, 80 bucks lifetime warranty.
Old Aug 12, 2010 | 07:48 PM
chillmiller
i got the lifetime
sooo sounds like im pulling it for the 5th time this year XD
i think my LT's are heat soaking the little buggers
Old Aug 13, 2010 | 02:30 PM
Duct Tape Racing's Avatar
Duct Tape Racing
starter relay possibly?
Old Aug 13, 2010 | 03:31 PM
chillmiller
O.o i never thought of that XD well i got the new starter godda love a lifetime warranty
illl check the relay
Old Aug 13, 2010 | 05:26 PM
chillmiller
so another starter
bench tested twice at autozone
came home hooked the main power up hooked a jumper to the nose of it and grounded that to the bell housing turned the key..... and nothing.... jumped the solinoid nothing....
so whats left? i doubt i have gotten 2 bad starters in a row i have put 3 solinoids on there one of witch was brand new the other came off a runner
battery's good dropped in another truck fired it right up
im losing sleep and work
Old Aug 13, 2010 | 05:27 PM
chillmiller
oh where would the "starter relay" be?
Old Aug 14, 2010 | 09:58 AM
chillmiller
hate to drag this back up but... still nothing....
its day 3 now....
still no closer to starting
help meh please
Old Aug 14, 2010 | 10:12 AM
Slip ford man
I just went through the same problem, long story, but in the end it was the battery...Ford starters need a lot of juice from a good battery...maybe you could try it with a charger set to boost. The relay is near the battery, just trace the pos. cable to find it, then again if you changed the solenoid you already got it, they call it different names sometimes. You could check the ignition switch, and the P/N safety switch and the cables themselves
Old Aug 14, 2010 | 10:26 AM
chillmiller
it might be my Nsafty see i lost my keys a while ago and said (beep) it and hot wired it o.O and how i start it is jumping the solinoid
Old Aug 14, 2010 | 10:42 AM
Slip ford man
The auto zone got a new key switch for under 20 bucks
