my wife washed my cell phone
Yup...it's true, I had a pair of shorts on and had my cell phone in my pocket. I changed my shorts so that I could go out and mow my dust bowl of a lawn.While I was doing that my wife decided to toss my shorts into the wash machine with the laundry.
I came in and said...where are my shorts,oh in the wash machine,so I said uh did you take my cell phone out of the pocket.ray:,nope....lol...great.
So my phone went through a complete wash even the spin cycle. I pulled my phone out of the wash machine and it was dead as a door nail.
My wife said I heard if you take the battery out any stick the phone into a bag of rice over night it may dry it out and work again,so I said yah right.
I had nothing to loose so tried the rice trick, I buried the phone in a plastic bag full of Uncle Bens, and woke up the next morning and low and behold the darn thing turned on and worked,I couldn't believe it.:yes1:
So if yah drop your phone into a puddle,sink,lake etc try this out,it worked for me.
Yes, the 'rice trick' absolutely works!
You might want to replace the battery, though.
My youngest daughter dropped her cellphone into the. . .ahem. . . toilet.
The phone was less than a week old.
The phone was opened and battery removed, placed into a bowl of (uncooked) "Minute Rice".
The battery was 'toast', but, the phone was like new, the next day.
Lastly, look inside the phone. There's a little 'label' that turns color when subjected to water.
(The cellphone company said that they won't replace a phone under warranty, IF it's been drowned.)
My phone sank to the bottom of a pool last year. I put it under a lamp with the battery out or a night and it helped, then did the rice trick and made it work 100%. I got a new battery just to make sure and it's still working to this day. It's amazing. Moral of your story: do your own laundry! Just kidding.
My youngest son did some laundry for his Mom, and put some Clorox in with her jeans.
Brad has been exiled from the laundry room. (I always knew that kid had a good head on his shoulders!)
If any thing will work, it will be the rice trick.
Leave the phone in the rice a minimum of 48 hours.
What will kill the phone is attempting to energize it with internal moisture present, so to err on the conservative side by leaving it in rice longer than may actually be necessary would be prudent IMO.
on
The IT guy at work was just telling me that alcohol also works - like, 90% isopropyl - I guess the theory is that the alcohol will remove the water and evaporate faster - he then suggested the rice thing after the alcohol 'dip'...
And then he started telling me how he spilled coffee on his netbook once, so he dumped a bottle of isopropyl alcohol on it to clean the coffee out - I guess it worked, miraculously enough, the netbook is still running to this day...
Rice? OK, I can go with that... Alcohol? yyeeaahhhh, I think I'll pass on that... Being a mild solvent, I can't help but wonder what it does to some of the plastic components... I've done board washes before, but that was after tearing the device down first...
Back in the dark ages, I worked for a company that did electronics assembly. I used an alcohol based solder flux to coat the entire circuit board assembly before wave-soldering. No muss, no fuss, 99.9999% perfect solder job. (yeah, there was the OCCASIONAL bad joint.... maybe one or two... )
-blaine
