need help with 390 FE
Old Aug 12, 2010 | 12:03 AM
79 f-150 guy's Avatar
79 f-150 guy
ok i am regasketing my recant 390 purchase and removed the intake. there is a tube on the intake that holds a small peice of heater hose that crosses to the water pump. the tube is rused bad and i tore what was left of it out with a vise-grip. now i dont know how to put a new one in, it aint threaded. the origional was pressed in. should i thread it and put a thread in strait fitting from the parts store or do i have to press in another one. anyone had this problem and if so what was your fix.... thanks
Old Aug 12, 2010 | 02:26 AM
miottimouse's Avatar
miottimouse
had the same problem years ago as those tubes seem to rust out drill and tap for a pipe thread brass nipple just make sure to start straight and use lots of pipe dope it will work good regurds joe
