c6 linkage
Old Aug 11, 2010 | 02:05 PM
blakebuckley's Avatar
blakebuckley
c6 linkage
i have a c6 on the back of a 460 with a np 205 t-case. i got a like brand new b&m mega shifter for it for $80. well where the linkage was suposed to mount to the pan bolts was right in the way of the front drive shaft. so i did a little modification to the bracket, well when i go to shift it out of park the shifter drops into the reverse spot but the tranny does not. once i get into the neutral spot it is then in reverse. so im always one spot below what actual gear im in. idk what to do. its a pain the way it is, did anybody else have this problem?
thanks<!-- google_ad_section_end -->
Old Aug 12, 2010 | 01:16 PM
83sd's Avatar
83sd
Is the linkage adjustable? Sounds like it needs.a minor adjustment
Old Aug 12, 2010 | 05:50 PM
blakebuckley
ya it is and i have played with it alot. to get it to go back in park it has to be pretty much the way it is.
