interior questions
Old Aug 10, 2010 | 07:48 PM
90fordguyohio's Avatar
90fordguyohio
interior questions
i have a 90 f150 i was wanting to kno if a 92 interior would mount right up? it looks like the heater controls are a lil different would this matter?
Old Aug 10, 2010 | 10:00 PM
TexasGuy001's Avatar
TexasGuy001
That will be alot more work than you want to do. You will run into wiring and probably vacuum line issues. The door panels are unique to the vent windows. It is doable but I'm not sure its worth it. Is your interior in really bad shape?
Old Aug 10, 2010 | 10:44 PM
90fordguyohio
no just wanting to change the color. is there any kinda of like vinyl paint or something? also how would i get the fabric on the doors the same color if there is a paint?
Old Aug 10, 2010 | 10:53 PM
TexasGuy001
That will take a lot of prep work to look good and hold up. It will still usually rub off and wear away. I would not do that, since it will most likely look bad in short order. If you want to change color, its better to just replace the peices with the color you want. What color do you have now, red? I would just look for 87-91 interior parts.
Old Aug 10, 2010 | 10:55 PM
90fordguyohio
yeh im not having any luck finding any gray interiors for a reg cab truck.
Old Aug 10, 2010 | 11:23 PM
TexasGuy001
Where have you looked? I would look at salvage yards and pick and pulls. It would be easiest to find a donor truck and take everything out of it.
Old Aug 11, 2010 | 07:30 AM
buck_'s Avatar
buck_
I did the same thing for my 89 F350. It had an awful red interior.
I got parts out of two different trucks and two Broncos. Now I have all the parts to change it over to gray once the rebuild is that far along.
I guess my point here is don't overlook the Broncos, and you may have to get parts from several different trucks. That is if you can find them. To bad your not closer, the junk yard a few miles from me has/had all kinds of Fords from those years.
Old Aug 11, 2010 | 09:08 AM
90fordguyohio
ive looked on craigslist junkyards pretty much everywhere i can think of
Old Aug 11, 2010 | 12:38 PM
90fordguyohio
would all the other panels fit pretty good like the pillar panels kick panels and the panels at the back of the cab?
Old Aug 11, 2010 | 07:38 PM
TexasGuy001
The Bronco panels should be the same from the seat forward. The cab corner trim will not be the same on the Bronco.
Old Aug 11, 2010 | 08:14 PM
goodB0Y's Avatar
goodB0Y
I repainted my interior with awesome results! One of the best things I did as it made my interior look like new. I had blue interior and changed it to grey. 2 years and it still looks new...
I cant remember the product I used but there are many... a google search will come up with plenty of products. A search here at FTE will also come up with a ton of threads on this.
I believe texasguy is right and most of the interior is the same on the broncos and F series
Old Aug 11, 2010 | 11:55 PM
90fordguyohio
so as for my question bout all the other panels besides the dash and the door panels being the same between the 90 and 92 model trucks?
Old Aug 12, 2010 | 12:29 AM
TexasGuy001
None of the interior parts even the kick panels, A pillar and B pillar trim etc is the same between 87-91 and 92-96.
Old Aug 12, 2010 | 09:51 AM
90fordguyohio
ok thanks for the help. what about the seat will that at least work lol my seat is pretty bad
Old Aug 13, 2010 | 12:24 AM
TexasGuy001
The later seat should swap out pretty easily.
