valve cover help
Old Aug 10, 2010 | 07:30 PM
nintey4f150's Avatar
nintey4f150
valve cover help
ok so i have a 94 f150 with a 96 351w swap... i put a trickflow stage 1 cam in along with ported gt40 heads the heads have stud mounted rockers arms and i had to cut the baffles out of the valve covers for clearance.. im pretty sure it pushing oil out now...so im wondering if anybody knows of aftermarket valve covers that i could get that would have the clearance for the rocker arms but also not be to tall to where it hits the upper intake?
Old Aug 11, 2010 | 08:28 PM
nintey4f150
anybody??... does anyone know if a tall valve cover will fit under the intake??
Old Aug 11, 2010 | 09:33 PM
danger-ranger93's Avatar
danger-ranger93
i dont know of any off hand but i did measure mine the other day to see if the extra set i bought off craigslist would work and from the top of the mounting plate to the middle of the curve and i 3 1/2" and there is about an inch or so of space between the intake and the top of the cover..if this dosn't help sorry but its a bump for you..
Old Aug 11, 2010 | 09:55 PM
86F150302's Avatar
86F150302
How about tall valve covers with an intake spacer?
Whoops didn't see your 2nd post.
Im 97% sure they wont. You will need an intake spacer.
Are you running stock truck intake?
Old Aug 12, 2010 | 05:13 AM
lew52's Avatar
lew52
The tall valve covers will clear the stock 5.0 intake , not sure about the 5.8.....Lew
Old Aug 12, 2010 | 06:50 AM
nintey4f150
well i would think the 5.0 an the 5.8 would have the same clearance... im gona try an get a measurement on the tall valve covers an see if there is room
htownoag
17
Oct 19, 2015 10:47 AM
FordOwnerJoey
Nov 9, 2014 07:22 PM
Hotrodhoarder
Apr 16, 2014 03:16 PM
Bobby Maguire
Feb 4, 2014 08:44 PM
jdmcivic23
Oct 8, 2010 01:11 PM
