electrical issues.
Old Aug 10, 2010 | 06:37 PM
85300's Avatar
85300
Exclamation electrical issues.
What would cause my lights on my 85 f150 to sort of flicker or go dimmer and brighter as the engine idles? my stereo also has some issues like it is not being able to pull enough amps.
Old Aug 10, 2010 | 06:41 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Loose connections or faulty voltage regulator.
Old Aug 10, 2010 | 07:27 PM
85300's Avatar
85300
where is the voltage regulator? are they cheap?
Old Aug 10, 2010 | 10:31 PM
Rogue_Wulff
Voltage regulator is either on the fender, near the starter solenoid, or inside the alt. 85 could be either location.
Old Aug 11, 2010 | 04:01 PM
85300's Avatar
85300
ok found it. fixin to put one on an see
Old Aug 12, 2010 | 04:56 PM
85300's Avatar
85300
fixed my radio jus ran my mem straight to the battery. sometimes i hate tha old truck but i wouldnt trade it for nothin
Old Aug 14, 2010 | 12:45 AM
amish77's Avatar
amish77
have you done the "big three"? if not I'd go ahead and upgrade the two main grounds and the main supply to the starter with the thickest wire available. This should help with any flicker problems.
