6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
SCT Live Wire
Old Aug 10, 2010 | 04:15 PM
fireman28's Avatar
fireman28
SCT Live Wire
Who is running the Livewire with the canned tunes and the DPF on? How is it? Is it worth the money? I know that the DPF off with custom tunes is the way to go, but I have too much warranty left to do all of that right now.
Old Aug 11, 2010 | 04:13 AM
Brandon D's Avatar
Brandon D
Lead Foot User
Just my opinion but you run just as much risk of voiding warranty when you run a tuner with the DPF on as you do with it off. The only thing you save is the time it takes to switch it out. So if you are truly worried about warranty then you might want to forget the tuner. The "tuner in a can" versions such as the SCT still flash the PCM and can be traced, they are actually supposed to be much easier to trace than the Banks or Spartan setups. Just want to make sure you are well informed before you throw your warranty out the window. Good Luck.
Old Aug 11, 2010 | 04:52 PM
sdetweil's Avatar
sdetweil
and doesn't dpf on leave all the soot in the filter which eventually will glog?
so, you end up with that trouble too.. disabling the regens and changing the fuel/air ratio is what makes the improvements..
if you don't do that, then whats the point?
Sam
9228.bobcat
Ford Truck Parts for Sale
May 8, 2014 06:25 PM
cmalley12
Jun 15, 2012 02:10 PM
cmalley12
Jun 7, 2012 10:10 AM
hilio
Jun 4, 2012 02:41 PM
