In cab heater
I've been frustrated looking for a fire-wall access port from the engine compartment into the cab to run the wire (i'll be running it to the front grill beside the block-heater cord).
I'll cut a hole if required but if you know of one I'll use it.
I'd rather ask here if a hole exists than rip up inside floor covers. Couldn't spot one from engine side but I haven't crawled underneath yet. Most access holes I've seen are jammed to the max with existing wires.
Two possibilities are enlarging the hood release cable hole (preferred) and the other is enlarging the throttle (gas pedal lever) hole.
Thanks.
