1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
step by step v10 valve job ??pics ?
Old 08-09-2010, 10:38 AM
mike bell's Avatar
mike bell
mike bell is offline
I am tearing in this morning....going to grab a chiltons or haynes.......would be nice to have some tips or a pictorial step by step.....any links ?????mike in Omaha
Old 08-09-2010, 12:22 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
avoid Chiltons and Haynes...
Old 08-10-2010, 10:26 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The best idea is get a Ford service manual, or CD/DVD.
Why does it need a valve job? Usually the entire motor is toast before it gets that far
Old 08-10-2010, 10:45 AM
redford's Avatar
redford
redford is offline
Received 1,628 Likes on 952 Posts
If you need guidance on a valve job, I would recommend just taking the heads to a competent machine shop to have them rebuilt. Specialized tools are required to replace the valve seats and machine the valve edges to the proper angle or angles that most people do not have in the average tool box. The cost of purchasing the proper tools is much more than paying a machine shop to do the same work.
Still, I'm with Krewat. Why do you think this engine needs a "valve job"? What problem are you trying to solve?
Old 08-14-2010, 11:43 PM
mike bell's Avatar
mike bell
interesting clues
I just bought this with 200 k......low end miss ( BAD ) smoothes out at 2000 RPM FIRST changed the oil and the plugs........still missing.....one plug came out with a collar and fouled......a week later that plug was fouled again...CHANGED ALL THE BOOTS.....still missing...the dealer stuck a scope down there ( to veiw the threads as the collar was not correct ) HE SAID OOH OOOOO and put everything away.....I said what does THAT mean he let me see in the scope A FOURTH OF THE VALVE WAS GONE !!dealer mech said the bottom end was propably good SOOOOO I pulled the heads half a dozen ex studs were broken anyway.....I beleive whatever FREAK put the wrong sleeve in there left chunks of metal in the chamber and busted stuff to heck......THREE OTHER VALVES ARE BURNT>........the great news is you can still see the cross hatches on all the bore holes...RO JAMS MACHINE shop in OMAHA has the heads they are being x rayed ...... PLANED ..... 3 angle valve grind ..... studs removed I AM CONFIDENT THIS ENGINE WILL BE BETTER THEN NEW !! WE WILL SEE SEE
59f100mike
03-07-2016 07:50 PM
mike1589
1997 - 2003 F150
06-07-2010 10:42 PM
Deerslayinrenek
03-23-2010 07:10 PM
Quick Reply: step by step v10 valve job ??pics ?
