Project ford f100 1956 new pics
#107
#108
If you want a column with shifter, I recommend a Flaming River column. It is what I used and as far as I know it the only one that has a lighted gear shift indicator. It also has the option of having the dimmer switch built into the tilt lever. I have had no problems with mine and consider the quality to be excellent!
#109
If you want a column with shifter, I recommend a Flaming River coulumn. It is what I used and as far as I know it the only one that has a lighted gear shift indicator. It also has the option of having the dimmer switch built into the tilt lever. I have had no problems with mine and consider the quality to be excellent!
Now I am looking for the 56 One Piece Door Window Kit
some guys here have that set
#110
Received 4,133 Likes
on
https://www.ford-trucks.com/forums/1...r-56-f100.html
I gave some information as well as others on that kit in the above link.
#111
Thanks but maybe stupid
I found this Complete 1956 Ford F100 One Piece Door Window Kits F100 Central
if there is a good set why make your own glass
#112
on
#114
on
Not a problem my friend, if you can save a buck on one thing your able to spend it some where else I'm planning to do a pickup when I finish my panel and hoping it is going to be some what cheaper to do. There has been a few things that I've purchased for my panel that I have copied or taken patterns from to lessen the impact to my wallet,lol. Have a happy new year.
#116
#117
on
#120
on
