abs warning light
Old Feb 14, 2003 | 01:14 PM
wally2117's Avatar
wally2117
abs warning light
I have a 93 Villager Van with the ABS dash light coming ON while driving, and never on the same conditions.
I scan the trouble code and it told me Code 25, front left sensor open circuit.
I checked this sensor and it test about 1kohms and generate small AC current.
I've also checked all wires and connectors. Made a continuity test to the ABS computer under the dash. All seems correct Cleaned all surfaces of the sensor and the ring.
Is somebody ever had a similar problem with ABS system, or have some idea of the kind of trouble it could be?
Thank you.
Wally
Old Feb 14, 2003 | 01:15 PM
pfogle's Avatar
pfogle
abs warning light
Bad senosor.... replace it problem go away.....
Old Feb 14, 2003 | 07:16 PM
Leo_T's Avatar
Leo_T
abs warning light
I was surprisd to find out the abs light will come on if the brake light bulb is burned out. That was on a GM, not sure about Ford. My mother learned that the hard way.
