351W question
Old Aug 8, 2010 | 09:03 PM
drunkdave's Avatar
drunkdave
351W question
I recently had 4.56's swapped in to my 89 bronco. The question I have is how how many RPM'S should I be able to safely turn at highway speeds.
Old Aug 8, 2010 | 09:47 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
That would depend on the shape of your engine and what you consider highway speeds. Here in Texas anything less than 80 mph will get you run over, which works out to ~3,500 rpm for your combo. At 70 ~3,000 rpm. Should be no worries, assuming your engine is tight.
Old Aug 8, 2010 | 10:05 PM
drunkdave's Avatar
drunkdave
well, I thought it was in my signature, but it has a c6 in it. So i'm turning about 3000 @ 60 mph, and thats all the faster i will go then.
Old Aug 9, 2010 | 07:30 AM
andyman7931's Avatar
andyman7931
I spin my 351 up to about 3400 rpm highway driving on a weekly basis. I don't like it, but when the speed limit is 70 and I want to do 75 I don't have many options.
Old Aug 9, 2010 | 08:48 AM
Encho's Avatar
Encho
The Southernmost Mod
Without and OD you'll make that engine scream at the highway...
Old Aug 9, 2010 | 10:22 AM
Conanski's Avatar
Conanski
Yes.. get yourself an OD transmission, an AOD would swap in pretty easily and drastically reduce highway rpms(2000rpm at 70mph), a 5-speed manual would bring it down to about 2500rpm at the same speed.
Old Aug 9, 2010 | 06:21 PM
Old Hickory's Avatar
Old Hickory
Any thing to to get away from the 1 to 1 ratio in high gear will help you.
