Patch panel radius forming
Old Aug 8, 2010 | 03:35 PM
MP&C's Avatar
MP&C
For those that may need to form up some patch panels but don't have those shrinker/stretchers at your disposal, here's a how-to on tuck shrinking.
Here are some "tucking" pliers I made out of neccessity when forming up a replacement piece for rust repair, and I'll have to admit, their biggest flaw is not providing accurate, consistent tucks. Of course, the operator could also be flawed.....
The more consistent the tucks, the more consistent the distance between them, in the end, the more consistent our radius will be. To improve on the tucks I'll start out by making a tool that will more accurately duplicate consistent tucks. We'll start off by finding a pair of vise grips suitable for the job, which in this case means the jaw serrations are starting to wear and round off. Finish what has started by removing the serrations to produce a nice flat jaw on the bottom, and cut the top one off at about 30 degrees from its original position.
I had some extra long shouldered 3/8 bolts, perfect round stock for the job. Three of them were cut off to 1-1/2" length.
Now because we don't have a fancy shrinker-stretcher machine likely means we don't have a lathe either. No sweat, use this economy model made by Dewalt...
To set the spacing for the "fingers" the first is clamped in the vise grip jaw, centered.
The outer is placed next to it and then welded down the outside, center finger removed, and then welded down inside.
Repeat for opposite side, then weld center finger.
Our new patch panel is bent up with about a 1" flange. Reference marks are placed one inch apart...
The first tuck shows how the radius starts to form. Slide the parallel fingers all the way against the bent panel and then squeeze the jaw closed. This will help to get the same depth of tuck each time.
Where I used an O/A torch, you should also be able to accomplish similar results with a hand held propane torch. (use what you have that works)
Heat up the raised portion of the first tuck until it glows nicely, then use a low crown body hammer (or suitable substitute) to flatten the tuck back into the flange. Repeat for the remaining tucks...
You can see we have a nice consistent radius, but likely it is not enough. Mark the next set of reference marks in between the first ones, just to stagger the shrink area to a new portion of the flange that has not been shrunk yet..
Where our flange is starting to form a radius, the outer edge has a tendency to remain flat. Rolling across a nice round piece of pipe while holding down gently on the edges will help (or whatever is handy....I will not be held liable for repurcussions from using stuff from your wife's kitchen..)
Repeat the process of heating and hammering the tucks....
Depending on how wavy the flange gets, you may have to go past the radius you are looking for to allow for flattening the flange
....and a comparison of the first and second, repeat as neccessary until you reach the radius you need.
Old Aug 8, 2010 | 08:51 PM
himmelberg's Avatar
himmelberg
Very cool... excellent explanation.
impressed, himmelberg
Old Aug 8, 2010 | 09:36 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
That is very impressive.Way beyond any skills that people like me can even dream of having.I would just have to open my wallet and pay the man for that kind of work.Steve
Old Aug 8, 2010 | 09:51 PM
52 Merc's Avatar
52 Merc
That's pretty slick. Thanks for sharing. My question is; how much, or how many times can you do the heating and hammering before it becomes work-hardened? How tight of a radius can you make?
Old Aug 8, 2010 | 09:52 PM
whateg01's Avatar
whateg01
Nice tutorial! I've seen others made from old vise grips too. You can also make different sized ones for deeper sections, though it gets tough if you have to go real deep into the panel. The tucking I've done was with a couple of 3/8" Allen wrenches ground round and pointed, then welded together. We clamped these in the bench vise or in a special stand that holds dollies, tucking forks, and other stuff.
I've never seen used a torch to soften the metal and allow it to shrink faster. If I was going to, I would heat it just til it starts to blue so that there is no mill scale to deal with later. Another thing I'd like to mention is that by heating the panel, the entire lower edge may shrink, so if you want a consistent radius all the way to the edge, the sides, not just the flange, may have to be restretched. Without a wheel, that can be tough to do smoothly, especially for a beginner.
I just made a tucking tool that works much like the stretcher/shrinkers, but cost a fortune less than even the HF models.
Oh, and it you heat it, you can't put it on a UHMW slab or use a UHMW hammer to flatten the tucks.
Nice tool though!
Dave
Old Aug 8, 2010 | 09:54 PM
whateg01's Avatar
whateg01
I'll add, for the benefit of others, that the tucking doesn't have to be done on a flange like that. You can do the same to a flat piece of sheet and put a crown in it. It doesn't take long to see the effect, but it does take a "little bit" of trial and error to get it right sometimes.
The first thing that I learned to tuck-shrink on was a motorcycle fender. Started with a flat piece of 20 ga. and ended up with something that looked kind of Indian-ish.
Dave
Old Aug 9, 2010 | 05:45 AM
MP&C's Avatar
MP&C
Thanks for the comments guys.
Each time you heat the metal (tuck) you should eliminate any work hardening that may, if at all, exist. I would think the possibilities should be endless as far as how tight a radius you could do. When the radius starts to get real tight, or if we were using a wider flange, you may see where it would be beneficial to alternate the depth of the tuck, one full depth of the flange, the next half the depth, etc. This would help as the inner radius (edge of the flange in this case) needs to be shorter in length than where the bend is, so by alternating the depth of tucks, you would have more shrinking there on the edge where it's needed, half as much ( or so) in by the bend.
Old Aug 9, 2010 | 08:02 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Very nice! great how-to
Old Aug 9, 2010 | 08:51 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Very well written and illustrated. As good or better than I can do with my shrinker/stretcher. Really should add to the paint and bodywork forum.
Old Aug 9, 2010 | 09:21 AM
sdetweil's Avatar
sdetweil
Each time you heat the metal (tuck) you should eliminate any work hardening that may, if at all, exist. I would think the possibilities should be endless as far as how tight a radius you could do. ...
'... should eliminate any work hardening'
how do you do that?
Sam
Old Aug 9, 2010 | 08:33 PM
whateg01's Avatar
whateg01
He means that the heating of the metal anneals it. You don't have to do anything special.
Dave
Old Aug 9, 2010 | 08:39 PM
sdetweil's Avatar
sdetweil
ok, better said
"Each time you heat the metal (tuck) you will eliminate any work hardening that may, if at all, exist"
Now, I know there are probably cases where this might not happen.
Sam
Old Aug 9, 2010 | 10:00 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Excellent tutorial!!!
Thanks for the pics and the write up
Bobby
MP&C
1983 - 2012 Ranger & B-Series
Oct 11, 2023 06:49 AM
MP&C
Paint & Bodywork
Jan 5, 2018 10:10 AM
MP&C
23
Oct 2, 2011 01:11 AM
MP&C
Jan 5, 2009 12:56 PM
