Here is what the spare hoist looks like with the bed removed;
[IMG][/IMG]
Tug the plastic tube off and you find this:
Here is the lock insert in place;
[IMG][/IMG]
Here is the lock insert removed;
[IMG][/IMG]
Remove the lock insert and the end of the jack crank should slide in to the hoist allowing you to raise or lower the spare.
Note that the insert has a hook end that is the same as the jack crank.
As you already have the spare out of the way you should be able to remove the insert by reaching over the bracket and under the bed with a screwdriver and pry it out.
Perfect timing. Had a flat last week and guess what? couldn't drop the F$%&#$g spare! I've been meaning to ask what to do about it. The tire shop suggested looking for the lock key, brand new used truck, and I couldn't find it anywhere.
Going to read the linked thread now.
When I had a flat I had the same problem. I located the key in a plastic pouch in the bottom of the glove box. (Don't know why they aren't stored with the jack. I got rid of my key also...
It doesn't hurt to drop the tire every now and then and check the pressure in it. Mine has 60psi every time I've checked. Another good thing for the guys with trucks that are a few years old, have that spare replaced! Mine is original, so thats a 10 year old tire. It looks ok, but I won't trust using it, so when the truck gets 4 new tires this month, one of the better used ones is going on that rim.
