What did you do to the X today?
Old 01-09-2019, 07:07 PM
copsey's Avatar
copsey
copsey is offline
Haven’t done anything lately but did order the Ford sealant for the HPOP. When I swapped mine last year I made a poor choice in using an anaerobic sealant I’ve always had great luck with and ignoring the recommendations of everyone to use the Ford goop. Will be resealing the cover along with fuel filters. May do the high idle mod at the same time, always forget about it and lonnyallison’s post reminded me it may be a good idea....
Hoping temps come back up after this weekend to do it all soon.
  #49367
Old 01-09-2019, 07:36 PM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
It was sad watching it drive away with it's new owners. It is headed to Florida. I gave them the FTE keychain and told them to come here for all the Excursion info and fellowship they can handle. Good luck with your new X Dan!
  #49368
Old 01-09-2019, 11:43 PM
agsmv1's Avatar
agsmv1
agsmv1 is offline
Had the wife drop her off at the shop to check the oil leak that is getting worse. I just do not have the time to check it or fix it right now. So leaking at the oil pan gasket, potentially the timing chain cover, and the valve cover gaskets....estimate- $4100!! Yikes...
  #49369
Old 01-09-2019, 11:58 PM
RedLance's Avatar
RedLance
RedLance is offline
LED Headlight upgrade
I recently completed a headlight upgrade and wanted to show some pictures.
I ended up using these housings: https://www.ebay.com/itm/400936399123
And these bulbs:
https://www.amazon.com/gp/product/B07GKWCYQD/ref=ppx_od_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07GKWCYQD/ref=ppx_od_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
The beam pattern is great! They have a very nice cutoff. I do not get flashed by on coming traffic. I did have to modify the bulb holder on the new housings to accommodate the wires for the new bulbs. I just had to shorten the collar that holds the bulb in the housing, since the wires on the new bulbs go down, instead of out the back of the bulb.
Anyway, here are the pictures.
The old headlight.
The new headlight with all new LED bulbs.
Both new lights giving it a pretty good look.
I had a couple shots showing the beam pattern but they didn't turn out for some reason...my phone needed to be factory restored, I suppose something was messed up. I'll get new shots taken as soon as I can.
  #49370
Old 01-10-2019, 07:52 AM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
Pulled mine into the garage to do some wintertime work on it, probably start with a clean and repack of the wheel bearings and check the brakes.
  #49371
Old 01-10-2019, 10:28 AM
jmren81's Avatar
jmren81
jmren81 is offline
And these bulbs: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The old headlight.
they look great. my 04 is in desperate need of a headlight upgrade. Im gonna pick these up. i may need some advice on shortening that housing when the time comes.
  #49372
Old 01-10-2019, 02:18 PM
RedLance's Avatar
RedLance
RedLance is offline
Sure thing. I may just post up some photos of the old housings and the new modified ones.
  #49373
Old 01-10-2019, 03:15 PM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
I for one am very curious to see the beam pattern. I bought 2 different LED kits and they were both garbage. Also had to trim the bulb retainer for the fan and wires.
Looks so much better with the new lamps. The OG ones were done-ha.
  #49374
Old 01-11-2019, 08:54 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
  #49375
Old 01-11-2019, 09:07 AM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
Dude you have nothing but trouble with that truck...
$4100?!? These mechanics are doing people dry...
  #49376
Old 01-11-2019, 10:18 AM
agsmv1's Avatar
agsmv1
agsmv1 is offline
No kidding! They get their share that is for sure!! Problems, not really, never done any major work to it, except for maintenance and the normal stuff that goes out. Never left me on the side of the road and runs like a top! That being said though I am going to go check out some 2018's this weekend...lol.
  #49377
Old 01-11-2019, 10:28 AM
SmackDaddy's Avatar
SmackDaddy
Sorry I’m reading this on my phone and the text us so tiny I thought you were another member with a 6.0 haha
  #49378
Old 01-11-2019, 10:43 AM
agsmv1's Avatar
agsmv1
agsmv1 is offline
Well the dealer did tell me they would give me top dollar for my EX.....as long as it was not a 6.0!!
  #49379
Old 01-11-2019, 11:43 AM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
The only way a 7.3 could leak from the valve cover gaskets is if they are not installed. I think someone isn't very competent at that shop. Also, the pan attaches to the front cover on the bottom, so it is very likely only your pan is leaking. Now, that isn't anything to downplay, as I am sure you are aware the engine has to come out to reseal the pan. There is no gasket on the oil pan...just sealant. Any rust on the pan?
  #49380
Old 01-11-2019, 02:34 PM
agsmv1's Avatar
agsmv1
agsmv1 is offline
Hence why I told them to just replace my front brakes, and a broken connector. I asked them to check it out as the brakes have been acting up. Trying to decide what we want to do. I may just sell it, or see how much I can get for trade in. Or keep it...lol.
Quick Reply: What did you do to the X today?
