What did you do to the X today?
Haven’t done anything lately but did order the Ford sealant for the HPOP. When I swapped mine last year I made a poor choice in using an anaerobic sealant I’ve always had great luck with and ignoring the recommendations of everyone to use the Ford goop. Will be resealing the cover along with fuel filters. May do the high idle mod at the same time, always forget about it and lonnyallison’s post reminded me it may be a good idea....
Hoping temps come back up after this weekend to do it all soon.
LED Headlight upgrade
I recently completed a headlight upgrade and wanted to show some pictures.
I ended up using these housings: https://www.ebay.com/itm/400936399123
And these bulbs:
The beam pattern is great! They have a very nice cutoff. I do not get flashed by on coming traffic. I did have to modify the bulb holder on the new housings to accommodate the wires for the new bulbs. I just had to shorten the collar that holds the bulb in the housing, since the wires on the new bulbs go down, instead of out the back of the bulb.
Anyway, here are the pictures.
The old headlight.
The new headlight with all new LED bulbs.
Both new lights giving it a pretty good look.
I had a couple shots showing the beam pattern but they didn't turn out for some reason...my phone needed to be factory restored, I suppose something was messed up. I'll get new shots taken as soon as I can.
And these bulbs:
The old headlight.
And these bulbs: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The old headlight.
The old headlight.
Looks so much better with the new lamps. The OG ones were done-ha.
$4100?!? These mechanics are doing people dry...
No kidding! They get their share that is for sure!! Problems, not really, never done any major work to it, except for maintenance and the normal stuff that goes out. Never left me on the side of the road and runs like a top! That being said though I am going to go check out some 2018's this weekend...lol.
The only way a 7.3 could leak from the valve cover gaskets is if they are not installed. I think someone isn't very competent at that shop. Also, the pan attaches to the front cover on the bottom, so it is very likely only your pan is leaking. Now, that isn't anything to downplay, as I am sure you are aware the engine has to come out to reseal the pan. There is no gasket on the oil pan...just sealant. Any rust on the pan?
