What did you do to the X today?
just fill to specified amount? IIRC when i did mine i couldn't add specified quantity to either axle, it was close but couldn't quite
Yes, and if you ever have to add friction modifier, the ABS sensor hole is about the only way to do that without making a mess. If you think gear oil stinks, wait till you smell the friction modifier.
Ford's original fill for that axle was synthetic, and the service fill called for synthetic. Pinion seal leaks are often the result of chemical incompatibilities and reactions between the seal material and the constituents in the lubricant... although it is more often the other way around, where diesters in a synthetic lubricant react with the elastomeric component of the seal. You have the reverse issue, where your pinion seal failed using a petroleum gear oil... which while unusual, is not unreasonable, given that Ford designed the seals for the axle to coexist with the synthetic lubricant originally specified. It could be that the seal, while perfectly compatible with synthetics, might end up swelling or reacting in some way with dino oils. There is a dizzying array of material property conflicts between seals and lubricants... makes my head spin. (e.g. Buna N rubber above 36% acrylonitrile is ok, but below 36% not ok, etc)
Of course if the engineers would simply specify using ONLY unga bunga X rubber, this would all be a moot point! Counting pennies I suppose.
Can i just remove vent on the front axle?
KR wheels installed. kinda regret the 265/70r18 instead of the 275/70r18. maybe next time saved me 125 this time around. look and ride way nicer. my wife however who doesn't care at all about vehicles says it still needs bigger wheels :/ she doesn't like how much space there is between the top of the tire and the fender arch......too used to cars and minivans i think....
get a pic tomorrow
get a pic tomorrow
get a pic tomorrow
get a pic tomorrow
Hell no! Leave the vent lines on both front and rear diffs and cover the ends with screen wire or a fancy diff vent line check valve. If the vent gets clogged your diff will pressurize as you drive and the fluid heats up and cause the fluid to be forced out the axle seals (rear) or the seals in the diff housing (front). I had both front and rear driver side leaks and found both of my diff vent lines plugged with mud dauber nests. If you guys don’t have mud daubers consider yourselves lucky. They wreck everything down here and there’s pretty much no way to stop the filthy little bastages! I have to put trash bags over my outboard motors and plug any holes with foil to keep them from building nests.
