What did you do to the X today?
Old 04-16-2018, 07:14 AM
Flyboy1100's Avatar
Flyboy1100
Flyboy1100 is offline
Originally Posted by Nicmike
It is a whole lot easier to remove the ABS sensor on top of the pumpkin and pour your gear lube in. Unless you like making a mess by adding it in from the side there.
just fill to specified amount? IIRC when i did mine i couldn't add specified quantity to either axle, it was close but couldn't quite
  #48077
Old 04-16-2018, 10:19 AM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
  #48078
Old 04-16-2018, 12:35 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Yes, and if you ever have to add friction modifier, the ABS sensor hole is about the only way to do that without making a mess. If you think gear oil stinks, wait till you smell the friction modifier.
  #48079
Old 04-16-2018, 01:37 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Received 3,349 Likes on 1,755 Posts
Originally Posted by Tbug05LTD
I believe it was 85W-140 valvoline petroleum based.
Ford's original fill for that axle was synthetic, and the service fill called for synthetic. Pinion seal leaks are often the result of chemical incompatibilities and reactions between the seal material and the constituents in the lubricant... although it is more often the other way around, where diesters in a synthetic lubricant react with the elastomeric component of the seal. You have the reverse issue, where your pinion seal failed using a petroleum gear oil... which while unusual, is not unreasonable, given that Ford designed the seals for the axle to coexist with the synthetic lubricant originally specified. It could be that the seal, while perfectly compatible with synthetics, might end up swelling or reacting in some way with dino oils. There is a dizzying array of material property conflicts between seals and lubricants... makes my head spin. (e.g. Buna N rubber above 36% acrylonitrile is ok, but below 36% not ok, etc)
  #48080
Old 04-16-2018, 02:15 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
this info seems confusing to me, but mainly because the new seals that you would buy fit the 10.25 and 10.5 axle that would cover from around 1985(Dino oil) to the synthetic axles. So I would venture a guess that the seal failure could just because of contamination/damage when assembled, or possibly the pinion nut backed off a tad. I’ve had new pinion seals leak for about a week and than just stop for no reason.
  #48081
Old 04-16-2018, 02:40 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is online now
Received 2,109 Likes on 560 Posts
Of course if the engineers would simply specify using ONLY unga bunga X rubber, this would all be a moot point! Counting pennies I suppose.
  #48082
Old 04-16-2018, 02:57 PM
Tbug05LTD's Avatar
Tbug05LTD
Tbug05LTD is offline
The petroleum-based gear oil was only in for about 10 days, now replaced with synthetic. Hopefully the leak will stop. The leak is only slight anyway.
  #48083
Old 04-16-2018, 03:49 PM
Flyboy1100's Avatar
Flyboy1100
been there.... now to look up quantity required again.
Can i just remove vent on the front axle?
  #48084
Old 04-16-2018, 03:53 PM
Flyboy1100's Avatar
Flyboy1100
Wife is driving X today so i could get a recall done onthe Odyssey, dont even get me going on that, <10min of work took over 3 hours.......
otherwise, got these babies mounted and roadforce balanced
  #48085
Old 04-16-2018, 04:52 PM
DavenTn's Avatar
DavenTn
DavenTn is offline
My bi-annual trek from FL to TN. 815 miles towing (on a car haul trailer ) my wifes loaded up Highlander. When I left FL it was 88* rained for 400 miles, now it's snowing in TN, 28*. 15.3 mpg.
  #48086
Old 04-16-2018, 09:21 PM
Flyboy1100's Avatar
Flyboy1100
KR wheels installed. kinda regret the 265/70r18 instead of the 275/70r18. maybe next time saved me 125 this time around. look and ride way nicer. my wife however who doesn't care at all about vehicles says it still needs bigger wheels :/ she doesn't like how much space there is between the top of the tire and the fender arch......too used to cars and minivans i think....
get a pic tomorrow
  #48087
Old 04-16-2018, 09:33 PM
DidieX's Avatar
DidieX
DidieX is offline
get a pic tomorrow
I think there's a tiny bit of rub with my 275/70 on the liner near the inside rear corner of the drivers side front wheel well. Only happens when I'm at full steering lock to the left and I hit a nice sized bump. For example, making a k turn and jumping the curb in the process. You New Yorkers know what I'm talking about...... I think I can just pull the liner back with some zip ties but with the 265/70 you shouldn't have this issue.
  #48088
Old 04-17-2018, 08:12 AM
Flyboy1100's Avatar
Flyboy1100
KR wheels
  #48089
Old 04-17-2018, 08:40 AM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
Hell no! Leave the vent lines on both front and rear diffs and cover the ends with screen wire or a fancy diff vent line check valve. If the vent gets clogged your diff will pressurize as you drive and the fluid heats up and cause the fluid to be forced out the axle seals (rear) or the seals in the diff housing (front). I had both front and rear driver side leaks and found both of my diff vent lines plugged with mud dauber nests. If you guys don’t have mud daubers consider yourselves lucky. They wreck everything down here and there’s pretty much no way to stop the filthy little bastages! I have to put trash bags over my outboard motors and plug any holes with foil to keep them from building nests.
  #48090
Old 04-17-2018, 08:00 PM
Dawnie Shinn's Avatar
Dawnie Shinn
Dawnie Shinn is offline
They sprayed the doors -
I have to go and see them up close and personal tomorrow to approve the color!
It was supposed to be Porsche Racing Yellow - but they lightened it -
Dawn
2002 X in makeover phase 7.3
Quick Reply: What did you do to the X today?
