What did you do to the X today?
Old 11-10-2012, 09:39 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
the 5.4 does great in the summer and on the highway i've seen close to 18 mpg on long highway drives, for a 1/2 ton its a great motor. for me fuel use has alot to do with driving style and idle time. i'm sure if i drove MUCH more conservative and felt like getting into a cold truck i could save a substantial amount of money. but alas no thanks.
  #10667
Old 11-10-2012, 09:43 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
im talking 5.4 excursion, not them little compact cars.
  #10668
Old 11-10-2012, 09:53 PM
Tom's Avatar
Tom
Tom is online now
It's not so much what I did to the X, but what I was able to get it to do. This week it pulled over 15,000 lbs nearly 1,400 miles. Huge fan of the V10 now!
  #10669
Old 11-10-2012, 10:52 PM
cw_mi's Avatar
cw_mi
cw_mi is offline
Put 355 miles on mine today. Decided for one more last ATV ride for the season with some friends. Got 7.8 mpg towing a 25' enclosed trailer with a Polaris RZR , two quads, gear and tools. Probably around #6000 total. I wonder if something is wrong, the last time I towed the exact same load at a little faster speeds I got a solid 9mpg. I don't know if they use a winter blend of gas like they do diesel because that might be the only difference I can think of. Time to change the PCV valve I guess.
  #10670
Old 11-11-2012, 12:10 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by b-uno
how do i get one for your special price?
Tousley Ford: $60.62
Ford Parts - Tousley Ford Parts Depot
Stewart
  #10671
Old 11-11-2012, 02:01 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
You may have a bad oxygen sensor. I know this is apples to oranges, but my '01 chubby 8.1L dually dropped from 11 down to 7 in the past few weeks. Nothing on scanner because it had not set the code. Then while idling the other day, the SES light came on. Sure enough, bad O2 sensor. Changed it and mileage went back up to where it had been. Bad thing is, I took a long time to notice it due to the short trips I had been taking in it.
  #10672
Old 11-11-2012, 02:03 AM
golfmedik's Avatar
golfmedik
Stewart
Awesome price there Stewart! I love our sponsors!
  #10673
Old 11-11-2012, 08:20 AM
cw_mi's Avatar
cw_mi
cw_mi is offline
Thanks for the info, I'll look into it. I guess the only way to know is to just change it right ?
  #10674
Old 11-11-2012, 08:33 AM
golfmedik's Avatar
golfmedik
I would scan it first as it may have a stored code that didn't keep the SES light on. My dually has 4 sensors at $80 a piece, not sure how many the Fords have. So, I made sure I had the correct one..My faulty one was on the left bank in the down exhaust pipe. Oh, and make it easier on yourself, if it is a bad sensor, and get the plug-n-play ones. Not the generic ones that you have to cut and connect the wires..
  #10675
Old 11-11-2012, 09:17 AM
cw_mi's Avatar
cw_mi
cw_mi is offline
Damn, did think they where that pricey. I will for sure scan for codes, now I have to dig up the directions for my Scanguage and actually use it for something more than just monitoring.
  #10676
Old 11-11-2012, 09:46 AM
golfmedik's Avatar
golfmedik
This is what the back side, lower end of the reservoir tank looked like after I got it out. This is the exact place where all of our ambulances had there problems. As you can see, not much longer and I would have had a leak.
Also, if it doesn't leak coolant there, it would lose pressure here. See the cracks in the top?
  #10677
Old 11-11-2012, 09:47 AM
golfmedik's Avatar
golfmedik
Your Scanguage should be able to do it. It also could be a failing air flow sensor as well. Scan and see what you get.
  #10678
Old 11-11-2012, 11:01 AM
golfmedik's Avatar
golfmedik
I'm glad it all worked out for you. Makes me want hook up something big to mine and go for a stroll!! Great info and looking very hard at the Derale Tstat when I ever get off my butt and put in my 6.0 cooler.
  #10679
Old 11-11-2012, 11:26 AM
EXv10's Avatar
EXv10
EXv10 is offline
You can check for those cracks/leaks by borrowing a tester from O'Reillys. It also has a cap tester on it which is how I discovered that 2 of my new caps were bad. A third one was good but didn't fit so that a 5 caps total I went through to get it fixed. Mine would just go into failsafe mode until fixed.
  #10680
Old 11-11-2012, 12:42 PM
cw_mi's Avatar
cw_mi
cw_mi is offline
Well, no codes at all. I'll try changing the PCV valve. It might not be anything at all ..
Quick Reply: What did you do to the X today?
