What did you do to the X today?
#8267
I did get my Gauges all wired and adjusted yesterday though. I need to call and ask them how to remove the low limit on the boost gauge though. I think it came set from the factory at 5psi or something so at idle the warning light flashes that it is below tolerance. You can see the red light lit in the pic. Very annoying!
#8269
#8273
1. Hold the set button for 5 sec. to enter into the low warning setting mode.
2. When the needle and warning light are flashing, you now can program the low warning mode value. Pressing the COLOR button will move the needle clockwise while pressing the set button will move the needle counter clockwise.
3. Holding either the COLOR button or SET button will move the needle in major increments in the buttons respective dirction.
4. After 5 sec of no button activity, the gauge will return to its normal operating mode.
5. To turn the warning sound on for this mode, turn the gauge off. While holding the SET button, turn on the gauge until you you a single beeping sound. Repeat to turn off.
Hope that helps my friend.
#8274
Received 5,160 Likes
on
#8276
on
#8278
on
#8280
Actually went to Skype with the family. They are in bed and I am following!
